Yes, MHV type. The question I'm surprised nobody has asked is, how do you DIY a decent gigohm and higher resistor? What materials might lend themselves to being the resistance element? Can you simulate a high value resistor to moderate frequencies with a floating battery powered opamp circuit, using easily obtainable values, to an accuracy higher than and actual device?
