Alrighty, assembly has begun, pictures incoming!
First pic: Markings on rotary switches. Anyone know who makes/made these?
Second pic: Side view of rotary switch.
Third pic: Front panel (Knobs waiting for shaft extensions) Does anyone know who makes these knobs? It'd be nice to get some that are numbered correctly (0-9, instead of 0-10 etc)
Fourth pic: Backside of front panel.
I have used 0.1% resistors where I could, 0.5% elsewhere (where 0.1% were not available).
Chunky 5W for the 0.1ohm, and 1W for the 1ohm and 10 ohm, 0.4W elsewhere up to 10GOhm 10Meg ohm.
Also, I have some questions....
I added the extra binding posts for 4-wire measurement, just because. Should I just hook the binding posts together, or run seperate wires to the first and last rotary switch? What is best practice here?
Also, for trimming the resistors, should I measure at the binding posts to take all the internal wiring into account? Set everything to 0ohm, then select 0.1ohm, measure trim, select 0.2ohm, measure, trim, select 0.3 ohm, measure trim, etc etc?
