Author Topic: HP3456A with isssues, worth buying ?  (Read 2517 times)
Offline DC1MCTopic starter
« on: January 21, 2018, 12:27:45 pm »
This thin here form Eastern Europe (Cehia) is it worth buying, or it's done ?
What price should I offer ?
https://www.ebay.de/itm/AGILENT-HEWLETT-PACKARD-HP3456A-6-5-digit-DIGITAL-VOLTMETER-with-ISSUES-HP-3456A/272996544330
Thanks,
DC1MC
Online alm
Re: HP3456A with isssues, worth buying ?
« Reply #1 on: January 21, 2018, 01:06:01 pm »
They are good meters, assuming a stable meter that can measure DCV, ACV and resistance is what you need. It's large compared to more modern equivalent like a HP/Agilent/Keysight 34401A and will not do current, but is more accurate and stable. Look for completed listings on eBay. Last time I looked (a number of years ago), the going rate in the US was around $100, so $275 shipped for a unit with known defects strikes me as high.
Online Vgkid
« Reply #2 on: January 21, 2018, 02:28:48 pm »
It is a bit pricey , but the error could be a problem with the power supply. That is known to cause intermittent faults after some time.
« Last Edit: January 21, 2018, 05:46:13 pm by Vgkid »
« Reply #3 on: January 21, 2018, 04:25:35 pm »
Thank you all for the answers, I will make the seller an offer, and I'm really thinking that we should have a stickie with precision instruments and their worth, along eventually with defect that make them not easy recoverable.
 Cheers,
 DC1MC
Offline Conrad Hoffman
    • The Messy Basement
« Reply #4 on: January 22, 2018, 12:32:30 am »
I don't know how different these are than my 3455A, but check the low voltage and low resistance ranges. If those are your main interests, you may find them wanting. Otherwise, they're a reliable and stable performer.
Offline MadTux
« Reply #5 on: January 22, 2018, 02:07:24 am »
If that 3456A was originally sold in Europe, it probably has the 50Hz line cycle frequency crystal on inguard digital board. Which makes it more desireable in EU, because sampling frequency matches line cycles. The ones from north America usually have crystals for 60Hz, so they are less acuate over here with 50Hz noise all over. These crystals have very uncommon frequency, so it's probable worth a bit of extra money....
The following users thanked this post: guenthert
Offline guenthert
« Reply #6 on: January 22, 2018, 02:05:07 pm »
Shoot.  I got a HP3456A purchased in the US (hence with Option 360 for 60Hz power source), but need it now in Germany.  Does anyone have a spare option 350 or has a hint what needs to be modified?  Ah, I believe I found it in the service manual p8-35 (thanks for the hint regarding in-guard logic): the uP's clock is given there as 5.85MHz for 60Hz power line and 4.875MHz for 50Hz.  But I wonder, if it isn't easier to import an UPS with an univeral input and 110V/60Hz output.
« Last Edit: January 22, 2018, 02:10:51 pm by guenthert »
« Reply #7 on: January 22, 2018, 04:19:10 pm »
No !!!
Use this thread:
https://www.eevblog.com/forum/buysellwanted/wanted-4-875mhz-crystal-for-hp3456a-multimeter/
