Hello 001,
from the internet "It's well known that the cheapest way to get an accurate resistor is to put many together; ten standard-grade metal film 10kΩ 1% resistors in parallel gives a 1kΩ resistor with a 0.3% tolerance for less money than a 0.5% part would cost."
WHY?
pricewise this is currently not true in my country.
Each time you sum something up the outcome is converging against a normal distribution.
This is obvious when looking at the formula for paralleling 10 resistors.
A simple way to understand it is the following:
Throw a dice once and write down the result.
Repeat this procedure a 100 times. How often do certain numbers appear?
Throw a dice two times, sum up the result.
Throw a three two times, sum up the result.
What happens with the sums?
Go and count which sum appears how many times and plot that on a graph.
By the way, if you ask questions in other threads you might consider answering people when they ask you.
It's disappointing for people that spend time on your questions when you don't react anymore.
Otherwise they might not take your questions seriously in the future and stop answering you.
Regards
try
