I noticed, that my Keithley 182 has a gain error of +1% in the 3mV and 30mV range. Therefore, I tried to recalibrate the meter. According to the manual one have to calibrate the internal divider first. Unfortunately the calibration of the divider fails (which explains why only the 3mV and 30mV ranges are out).
I can run a calibration of the 30mV range (haven't tried 3mV but I should also work) without further errors, but the +1% errors stays the same. I think this is due to the (broken?) internal divider respectively the wrong gain factor.
Does anyone know this problem? I haven't open the unit until now.
Best regards
Philipp
