Author Topic: Low-cost temperature and aging stable voltage reference recommendation?  (Read 2237 times)
Offline forrestcTopic starter
I'm in the process of redesigning a few products around here which currently use a 50ppm/C reference (MCP1525).  Long-term aging is not specified (other than a chart showing a +-20ppm aging occurs in the first couple hundred hours after power on).   Of course, any redesign is an excuse to look at the parts to determine if we can do better.   Plus we've gotten some feedback from customers who would prefer we improve our accuracy over temperature.
So, what I am looking for:
This is a 3.3V design with no additional voltages available.   The reference needs to output a voltage somewhere below that.  2.5V seems to work well.    A stable Vref/2 output is also a big bonus cause otherwise i'm stuck doing a voltage divider there which means more resistor ppm errors (unless I spend more $ on a matched tempco resistor divider).   Of course, if the combination of a voltage ref+appropriate divider is less expensive, I'm definitely open to that as well.
The challenge in this application is that the circuit will be exposed to +-40C swings from the cal point. (-20C to +60C operational range).   We are measuring battery array voltages which are +-60V and want to be accurate to +-0.1V (I apologize if I just used the wrong term for accuracy vs precision).   If I did my math correctly, I figure I have at most ~1000ppm to work with, and probably a fair bit less than that.  A 50ppm reference * 40C is 2000ppm.  So obviously I need something better if I want to meet this desired spec - probably something in single digit PPM/C range once one accounts for other component temperature drifts.
This is in a solar-powered application so power consumption is important.   This along with the extreme temperature range and cost seems to eliminate most/all ovenized solutions.
Since this is going to be calibrated, I'm not fussy about the initial voltage accuracy - as long as it's in a usable range.  A 2.5V+-10% initial accuracy reference with low aging/temperature ppm is no problem at all.
I've found TI's REF2025 which is a 8ppm absolute + 6ppm Vref/2 tracking voltage reference which looks pretty good.   It's ~1.75USD@1K which is tolerable if I absolutely had to, but I'd rather find something < $1 at that quantity.
I'm hoping some of the volt-nuts on here can possibly point me toward some parts or other design strategies I've missed.
Offline mycroft
  • Country: br
Re: Low-cost temperature and aging stable voltage reference recommendation?
« Reply #1 on: August 01, 2018, 01:54:14 am »
Take a look at this thread: https://www.eevblog.com/forum/projects/how-good-or-bad-are-tl431432-type-references/ maybe you will find something interesting.
The following users thanked this post: forrestc
Offline Muxr
« Reply #2 on: August 01, 2018, 10:25:20 pm »
You should also check out LTC1043. You could use it to divide the vref by 2 (or 3) (see app notes in the datasheet), without using expensive resistors. Just make sure you buffer the output with something like a LTC1050 since a lower impedance input could increase the error of the LTC1043.
Offline GigaJoe
« Reply #3 on: August 02, 2018, 04:28:14 am »
REF5025 - diff grade;  V trim pin, possible to add V - temp  correction, soic better then sot-23;   +would be humidity effect, due to outside exposure.  ideal case ceramic , but it around $7
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #4 on: August 23, 2018, 12:56:49 pm »
IMHO a heated reference is a good solution, especially of the environmental temperate changes are very large.
It will even those out, and long term drift is the only remaining problem.
Just as a try, I made one out an LM723 that heats itself, and it is fairly stable. Output voltage can be adjusted to what you want.
https://electronicprojectsforfun.wordpress.com/silly-circuits/silly-circuits-a-heated-lm723-reference/
If you dont like this one, I would recommend an LM399.
The following users thanked this post: cellularmitosis, Marco1971
