I have some banana plugs from the audiophile world - they look like hollow tubes, and are gold on silver on copper. I use a drop of the CdSn solder to secure the inner conductor of the coax to the inside of the plug.
The hollow tubes (spring type copper alloy) are based on CuBe. CuBe has a worse EMF than CuTe. If you want low EMF (which I have doubts you do measure, tbh), you better start with CuTe, no need for SnCd. Or in other words, any potential effect of the SnCd will be covered by the CuBe EMF (which, again, you probably will not see anyhow, unless, it at all, you are working in the 100nV and below range/resolution; i.e. a 34420 or the like). And secondly, a EMF voltage in the small solder spot you mention will only be generated if there is a temperature delta accross it. In such a small spot obviously pretty impossible. The CuBe will equalize all temperature delta over the spot's lenght/cross section of a few millimeters only.
One can do many things every day, some of which make more, some of which make less sense. The use of SnCd is pretty much on the bottom of that scale.
