Author Topic: LT3094 -ve LDO equiv to LT3045  (Read 4411 times)
Offline alanambroseTopic starter
« on: August 28, 2018, 09:16:08 am »
Hi, FYI I just noticed this comment:
https://ez.analog.com/thread/109212-can-the-lt3045-be-used-to-regulate-both-a-positive-and-negative-voltage-rail#comment-361010
... but can't see other info atm.
Alan
{edit - I meant 3045 rather than 3095}
« Last Edit: August 28, 2018, 10:54:01 am by alanambrose »
“A foolish consistency is the hobgoblin of little minds"
Offline TiN
  • Country: ua
    • xDevs.com
Re: LT3094 -ve LDO equiv to LT3095
« Reply #1 on: August 28, 2018, 09:20:56 am »
I've used LT3092, it's nearly same as 3042/45.
Online coppercone2
Re: LT3094 -ve LDO equiv to LT3045
« Reply #2 on: August 28, 2018, 11:42:47 am »
Can you link a picture so we don't need to register to AD website (ridiclous)
I assume you are asking about making some kind of negative LDO that has a ridiculously low noise floor and great RF PSRR ?
I don't see a LT3094 chip?
I noticed in general there are no good manufactured equivalents of chips in the same ball park, maybe because of PNP stage?
You said 94 now 95 and 45 can you fix everything I am very confused.
« Last Edit: August 28, 2018, 11:47:18 am by coppercone2 »
Offline Echo88
« Reply #3 on: August 28, 2018, 11:51:39 am »
Seems they changed the Analog.com-Forum to log in only this day.  :palm:
Anyway: https://www.mouser.com/pdfdocs/ADI_LDO_General_Presentation_2018Apr1.pdf The LT3094 seems to have the same specs as its positive LT3045-brother.
Online coppercone2
« Reply #4 on: August 28, 2018, 07:57:11 pm »
I am excited for that part. The order of magnitude difference was very irritating IMO. ~0.8 vs 18 !!!
« Reply #5 on: August 30, 2018, 10:03:48 am »
Apologies for the slightly cryptic and erroneous initial title.
Yes I think this is of general interest here.
Wow, that's a nice presentation.
Amazing to see the favourable comparison with Li-ion noise; the absolutely critical layout; and the magnetic field analysis.
Alan
Offline Echo88
Offline splin
« Reply #7 on: September 10, 2018, 10:46:07 pm »
The 3042 and 3045 are pretty expensive, so how much might an external pass device, to increase output, compromise the noise performance?
What is likely to be the biggest factor behind the big improvement over previous regulators? Reference noise perhaps?
Offline Echo88
« Reply #8 on: September 19, 2018, 10:22:10 pm »
Update: Digikey has the LT3094 in stock, while Analog.com still doesnt list it as a part.
Offline branadic
  • Sounds like noise
« Reply #9 on: September 20, 2018, 08:03:15 am »
Designed as a precision current reference followed by a high performance rail-to-rail voltage buffer...
instead of a voltage reference.
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
Offline MiDi
  • Country: ua
« Reply #10 on: September 24, 2018, 11:58:04 am »
Luckily this seems not to be an April's fool  :-DD
Offline MiDi
  • Country: ua
« Reply #11 on: October 18, 2018, 05:16:51 am »
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #12 on: October 18, 2018, 05:26:23 am »
I got few some weeks ago from Digikey, but they still sit in ESD bag :)
Offline MiDi
  • Country: ua
« Reply #13 on: October 18, 2018, 08:11:52 am »
If you are curious whats inside the christmas cookie box: take a look at AN159
Offline Gerhard_dk4xp
« Reply #14 on: October 21, 2018, 05:44:14 pm »
It is not much worse.
<    https://www.flickr.com/photos/137684711@N07/29452163806/in/album-72157662535945536/       >
Circuit is like the one in the data sheet. Measurement was quick & dirty without the
second alu coffin.
<   https://www.flickr.com/photos/137684711@N07/29197476530/in/album-72157662535945536/    >
To the left / right are measurements of other devices that might be interesting.
The stronger than 1/f increase of the noise at low frequencies is my preamplfier, the input capacitor
was too small for an effective bias network short.  -3dB is not everything. :-)
That has been healed with a wet slug tantalum; I intend to repeat the measurement campaign with
the new version of the amplifier.
0 dB == 1 nV/rt Hz.
The reference is a current source; that is much easier to decouple than a low impedance
voltage source. Don't overdo it with the output capacitor or you'll get noise peaks.
regards,
Gerhard
« Last Edit: October 21, 2018, 05:51:51 pm by Gerhard_dk4xp »
