Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Metrology
METRIX MX57EX
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: METRIX MX57EX (Read 2935 times)
lionelkjh
Frequent Contributor
Country:
METRIX MX57EX
on:
November 27, 2016, 02:51:08 pm »
Hello everyone! I have a high-end Metrix mx57ex, and I also have calibration software. I do not have the link of the multimeter to the computer. I have in my possession an eeprom programmer (TL-866CS) and I was able to extract the memory (93C46). So my question is: is there a way to read from the Metrix calibration software the contents of the eeprom memory (bin file), to correct some errors in calibrating the multimeter on the 'computer?
Thanks in advance for your help in this headache that I try to elucidate .....
Logged
lionelkjh
Country:
Re: METRIX MX57EX
Reply #1 on:
November 29, 2016, 12:07:15 pm »
sniff!
Logged
2N3055
Super Contributor
Country:
Re: METRIX MX57EX
Reply #2 on:
November 29, 2016, 12:27:08 pm »
My advice would be to buy/make a cable and not tamper with the imstrument...if you have cal software..
Logged
lionelkjh
Country:
Re: METRIX MX57EX
Reply #3 on:
November 30, 2016, 11:43:05 am »
Hello; thank you for your reply. How to make the cable
(The original cable can not be found) ......
Logged
macboy
Super Contributor
Country:
Re: METRIX MX57EX
Reply #4 on:
November 30, 2016, 01:44:05 pm »
The cable is simple to make. Refer to my old post at
https://www.eevblog.com/forum/testgear/metrix-mx56c-bk-precision-5390-multimeter-teardown/msg268678/#msg268678
You need a USB UART converter ($1 to $2 on ebay etc.), plus a IR LED, an IR phototransistor, and a couple resistors. You wire the IR LED to the transmit side of the USB UART - use a series resistor of about 1k and wire the cathode to the Tx pin and anode to the +3.3 V pin. You connect the phototransistor to pull the Rx pin low when receiving (use a pull up resistor also). If you point your LED at your phototransistor, you should receive whatever you transmit on the serial line using a terminal program like putty or hyperterminal. If you block the light path, it should stop echoing. After that works you can try to talk to the meter. The simplest thing to do is press PRINT key to get a reading as ASCII text over the serial link (open the port at 2400/8/N/1). After that works you can try the software.
Logged
lionelkjh
Country:
Re: METRIX MX57EX
Reply #5 on:
November 30, 2016, 06:40:31 pm »
Good evening: thank you for this precise answer! A question still crosses my mind: Is there a universal software for all multimeters to calibrate (with the interface you mention), and how to get it
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Metrology
METRIX MX57EX
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
