According to the manual, the accuracy specs are good after a 5 minute warm-up.
In DCV mode, the meter takes a new measurement every second. There is a fluctuation in the last digit, which gets a little less with time. In my experience (I can't guarantee the test is free of outside interference), the fluctuation stabilizes at about 3 to 4 counts on either side of the mean.
The meter has a filter which can be set to 1, 2, 4, 8 or 16 samples running average.
The test was done in the 10V range, with a resolution of 10uV, measuring a AAA battery voltage.
