Hi
Sorry
I`m old but havent any grafuate in electronix
Me neither, but I am maybe not so old.
If I read voltage with (0.03%+2d) voltmeter around 0.005% resistor what is result current tolerance?
Thanx!
Without telling the forum the number of counts, the measurement value and range used nobody can give you an exact figure.
With no correlation effects the uncertainties will add up so that the resulting uncertainty is at least 0,035%.
Low readings in a range will make that figure explode due to the increasing weight of 2d.
=> The value of 0,035% is pretty meaningless for you.
Regards
try
