Author Topic: Noise Article  (Read 1850 times)
Offline VintageNutTopic starter
Noise Article
« on: November 06, 2016, 03:20:54 pm »
Excuse me if this has been posted before.
A recent finding that noise is a bulk phenomenon unless your device is 1 atom thick.
working instruments :Keithley 260,261,2750,7708, 2000 (calibrated), 2015, 236, 237, 238, 147, 220,  Rigol DG1032  PAR Model 128 Lock-In amplifier, Fluke 332A, Gen Res 4107 KVD, 4107D KVD, Fluke 731B X2 (calibrated), Fluke 5450A (calibrated)
The following users thanked this post: BravoV
Offline Echo88
Re: Noise Article
« Reply #1 on: November 06, 2016, 03:56:30 pm »
"You kids today have it so easy, with your mobile JJAs which are as big as a pack of cigarettes and your 1-Layer-Graphene-OP-AMPS which have no noise. In my time we had to deal with shitty carbon resistors and lithium accupacks which would explode if not handled right!" *angrily stomps his walking cane on the ground*
Offline Gyro
Re: Noise Article
« Reply #2 on: November 06, 2016, 04:30:44 pm »
Actually 6 atoms thick. At that thickness surface noise dominates, above than bulk noise dominates (in Graphene anyway).  :P
Best Regards, Chris
