hello all,
help required.
i am trying to simulate the reference part of LM399 (LM329) using ltspice, but running into trouble,
maybe i am using the wrong transistors, (i am using THAT3XX models), or can't adjust the resistors marked for factory adjustment,
or maybe using 6.2V zener instead of 6.3V is a problem. (maybe use 2DW232 model here?, could be interesting)
the voltages and currents work out approx. ok but i should see a hump for a temperature range 0-100degC around 90deg, or any
hump at all, which i cant see.
i have also tried to simulate for a hump using the tesla supplied schematic diagram, (i do see a hump in the bypass transistor collector current
which is only in the tesla schematic as T18).
attached is the schematic / ltspice file.
comments required from learned members of this forum.
