Author Topic: Plugs to fit rear panel circular connectors for Datron 4808  (Read 2160 times)
Offline perdrixTopic starter
They look like the mating connectors might be Lemo FGG.2B.306.CLAD92Z but I'd like confirmation if possible before firing off an order as they aren't dagger cheap.
Thanks
Dave
Online Vgkid
Re: Plugs to fit rear panel circular connectors for Datron 4808
« Reply #1 on: July 11, 2017, 11:42:05 pm »
Pictures.
Offline quarks
« Reply #2 on: July 12, 2017, 01:05:15 am »
As I have already written elsewhere, the original connectors are from LEMO.
In the 4808 and 4600 are EGJ.2B.306 and EGG.2B.306.
The mating plugs are FGJ.2B.306 and FGG.2B.306.
You can get them in crimp and solder versions.
I personally much prefer to crimp,
But crimping is only an option, if you also have the necessary crimp tools.
« Last Edit: July 12, 2017, 07:51:51 am by quarks »
The following users thanked this post: CalMachine
« Reply #3 on: July 12, 2017, 08:08:49 am »
Thank you
Dave
« Reply #4 on: July 12, 2017, 08:31:55 am »
Just to be 100% sure - I think these are wired straight through 1-1, 2-2 etc.  Is that correct?  Is that same also true of the Db15 cables?
Thanks again, Dave
Offline quarks
« Reply #5 on: July 12, 2017, 02:46:37 pm »
If I remember correctly all cables are just 1 to 1 connections
Offline syau
  • Country: hk
« Reply #6 on: June 28, 2019, 02:22:53 am »
Found some alternative from Aliexpress:
Male Plug LEMO FGG.2B 6 pin
https://s.click.aliexpress.com/e/dbm34MC
Female Plug LEMO FGG.2B 6 pin
https://s.click.aliexpress.com/e/b9WHYO64
Have ordered some pieces, the build quality is excellent.
Tested both connectors on my 4708 and 4600, they are mechanically fit.
« Last Edit: June 28, 2019, 03:11:02 pm by syau »
