« Reply #57 on: May 04, 2018, 04:31:00 pm »
After a bit more research I see someone asked time-nuts back in 2005 Board 55761
[time-nuts] Unknown Efratom 10MHz Assy, information asked
answered:
The board you are describing is used in the Lucent RFG-M-XO reference
frequency generator. It takes in 10 MHz on J2 from a Rubidium oscillator and
disciplines the Efratom SC cut OCXO on the main board from the 10 MHz input.
The output from the OCXO is converted to 15 MHz and supplied as the
reference output on J4.
The RFG-M-RB and RFG-M-XO normally mount together in a chassis
Well Maybe
« Last Edit: May 04, 2018, 04:45:18 pm by Johnny10 »
Logged
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
