Now while a wee bit too large to be placed onto a PCB, those "Thomas style" (? the construction seems very similar, although at 10kOhm the used material will be quite different from those super-stable 1Ohm resistors) certainly count as precision resistor. This soviet made P331 is of the .01% class (don't know over which temperature range that applies) and well aged. I received it only recently (via Fleebay from Ukraine) and can't offer any long term drift data. I don't have a climate chamber either, so I put the DUT out on the balcony in the morning and after about an hour brought it back in and measured it while it warmed up to room temperature (which is currently fairly high).
Neither my Datron-Wavetek 1271 (which I used to take the measurements for the plots below) nor my HP34401 are recently calibrated (if ever), but they eerily agree about the value of this resistor (so much even, that I fear some mind-over-matter mechanism is in play
The plots are from two sessions a week apart. Each consists of multiple series with data points roughly distributed equal in time.
The near-zero TC point seems to be close to 300K, which puzzles me. Is this by accident or intention? Did its zero-TC point perhaps drift over the years or was the resistor meant to be used in a warm air or oil bath?
With some good will, one recognizes a parabola there, which is a bit deformed in the left leg (early measurements) of the first graph. Not sure, what caused that, but I'd guess, that there the temperature of the DUT was rising too quickly, so that the temperature as reported by the NTC in the thermometer well didn't well reflect the actual temperature of the resistance wire.
