Author Topic: Volt reference DIYer LTZ 10V PWM  (Read 16084 times)
Offline 0.01CTopic starter
  • Country: hk
« on: July 02, 2017, 02:03:42 am »
I got it from a Chinese DIYer
« Last Edit: July 02, 2017, 01:16:44 pm by 0.01C »
0.01℃
The following users thanked this post: ManateeMafia, Muxr, CalMachine
Online Vgkid
Re: Volt reference DIYer LTZ 10V PWM
« Reply #1 on: July 02, 2017, 03:09:48 am »
Do you have a schematic for that. What are the 2 covered sections. 1 is the reference, what is the other (lower one) ?
  • Country: hk
« Reply #2 on: July 02, 2017, 03:23:23 am »
I don't have ,  the lower one is a ferrite core cord ring
this pwm board was purchased for a eevblog member.
« Last Edit: July 02, 2017, 03:54:22 am by 0.01C »
0.01℃
Online Echo88
« Reply #3 on: July 02, 2017, 09:52:09 am »
Looks to me like the rebuild of a Datron 4910, since i see the bottom part with the 5-pole-filter but no top notch resistor-arrays like in the 5700A-PWM-DAC.
If i may ask: How much did it cost? It looks nicely made and the layout looks suitable.
« Last Edit: July 02, 2017, 10:05:26 am by Echo88 »
  • Country: hk
« Reply #4 on: July 02, 2017, 01:15:02 pm »
about USD158 , WIMA capacitor is second hand ,other parts are brand new.
0.01℃
Online Echo88
« Reply #5 on: July 03, 2017, 02:18:29 pm »
If you still have the board, could you make a few more detailed photos please? Id like to see which ICs were used and compare the board to the Datron 4910 schematic.
« Last Edit: July 03, 2017, 02:20:41 pm by Echo88 »
Offline picburner
« Reply #6 on: July 03, 2017, 09:49:02 pm »
On bbs.38hot.net I found this schematic: it is not the same version of the pcb posted by 0.01C but this is inspired by the Datron 4910 also.
Offline Kleinstein
« Reply #7 on: July 04, 2017, 03:39:59 pm »
That circuit looks quite different from the boards used. The PWM modulator and filter is very much like Datron 4910 including going the old way the JFETs and NE5534 - a more modern replacement would be audio grade JFET OPs. The rest looks somewhat different and strange in some places - it even looks like it might get easily unstable (at least I would expect C68 at a slightly different place - as shown it is more like a problem).  It is only the PWM generation from an µC that looks more modern - not the old style with 74HCxxx.
So the plan might be similar in intention, but looks different in the details.
  • Country: hk
« Reply #8 on: July 06, 2017, 01:55:13 pm »
noise amp x10k , reading 25mVpp  :popcorn:
https://youtu.be/vKPXxuj6usQ
« Last Edit: July 06, 2017, 02:01:35 pm by 0.01C »
0.01℃
Offline lukier
    • Homepage
« Reply #9 on: July 06, 2017, 03:54:52 pm »
Interesting amplifier, do you have any details?
Is that based on zlymex design (0.1-10Hz, 10k gain)
https://www.eevblog.com/forum/metrology/diy-low-frenquency-noise-meter/
or more similar to Tek's AM502 (looks like, gains and frequency ranges)?
  • Country: hk
« Reply #10 on: July 06, 2017, 05:00:31 pm »
I bought the amp. from my friend CNY300,I think it is based on lymex design.
0.01℃
The following users thanked this post: zhtoor
Offline zhtoor
  • Country: pk
« Reply #11 on: July 06, 2017, 05:59:22 pm »
thanks, could you point at a place where one could be bought?
regards.
Offline Andreas
« Reply #12 on: July 06, 2017, 09:46:13 pm »
Hello,
Without putting the DUT battery supplied into a shielded environment?
Unbelievable. Where is the mains hum?
with best regards
Andreas
  • Country: hk
« Reply #13 on: July 07, 2017, 01:46:58 am »
Hello,
with best regards
Andreas
The reading is magnified by the noise amplifier by 10k , that ltz pwm ref. noise is about 2.5uVpp
0.01℃
  • Country: hk
« Reply #14 on: July 07, 2017, 01:53:51 am »
regards.
My friend said there are still have five sets , but he needs time to welding and test, may be the end of the month to sell,
0.01℃
Offline Andreas
« Reply #15 on: July 07, 2017, 06:20:34 am »
Mhm,
what are the H and the L LEDs for?
are they "overdrive/clipping" indicators?
Without a shielded environment and with all those switchmode supplies on the same mains outlet it is most likely that the scope is showing something wrong.
with best regards
Andreas
Offline lukier
    • Homepage
« Reply #16 on: July 07, 2017, 06:25:49 am »
Is the schematic open source? I would be keen to see how he implemented switchable frequencies and gains - this is missing from the original lymex design (fixed 0.1-10Hz, 10k gain).
Offline Kleinstein
« Reply #17 on: July 07, 2017, 07:06:55 am »
Only 2.5 µV_pp of noise is quite low.  Filtering of the supply of the reference circuit should not be that important, as there is already a DCDC converter on the board - so the supply filtering needs to be on the board anyway. If the PWM filtering is low enough it might be effective against 100 Hz ripple, maybe even 50 Hz.
The noise measurement amplifier seems to use 3 independent low pass filters und thus likely 100 kHz as the full bandwidth of the amplifier.  Normally the setup should be something like  x100  - 0.1 Hz high pass filter, maybe x 10 - low pass filters with switches  - switchable amplifier x 1 / 10 / 100 .
  • Country: hk
« Reply #18 on: July 07, 2017, 04:03:44 pm »
regards.
Hi ,
My friend finished 4 sets today, he will placed it in Taobao for sell tomorrow, and he also want to give 5 pieces ltz pcb (pcb only) to eevblog member for free.
0.01℃
The following users thanked this post: CalMachine
Offline lukier
    • Homepage
« Reply #19 on: July 07, 2017, 04:22:39 pm »
Nice!
I'm actually planning something similar - DIY Fluke 734A, that is 4 LTZ1000 based 10V reference modules, each with 10K reference as well. For now I have all the parts for the 7V reference circuit and 10K resistors (VHP202Z) and I need to design the board. Once I finish that and the references will be aging I'll have plenty of time to figure out other circuits in the module (battery + power supply/charging, 7->10V step-up, mini-oven for VHP202Z 10K maybe, small signal relay to switch output between raw 7V and 10V, output protection etc.).
He must have excellent access to parts, all the oil filled Vishays, hermetic LT1013 and so on. Many months ago I requested a quote from Vishay, as I wanted to buy the LTZ1000 resistors and 10K reference (5 sets) and I got completely ignored, so I got second hand resistors (non-oil filled Vishays for LTZ1000 and VHP202Z) from eBay and the remaining parts (including LTZ1000 and LT1013 DIP8) from DigiKey.
Interesting power/voltage connection with the bare wires soldered between the mini-module and the base board. I've decided to go the 3458A reference module route and planned pin header connectors. Are bare wires better with respect to thermal EMF?
The following users thanked this post: bob.cmhk
  • Country: hk
« Reply #20 on: July 07, 2017, 04:42:08 pm »
We have done several times group buy vishay resistor ,VHP101T 100R 9.998K ,VHP202 9.998K  ,VHD200T 6K3:13K8........
0.01℃
The following users thanked this post: dr.diesel
  • Country: hk
« Reply #21 on: July 07, 2017, 04:50:01 pm »
Nice!
Do you want the 7-10 and ltz ref. PCB ?I can send you one set.
0.01℃
The following users thanked this post: lukier
Offline lukier
    • Homepage
« Reply #22 on: July 07, 2017, 04:57:12 pm »
Sure, I'm planning four 10V-10K reference modules, but I have parts for 5 sets (backup) so I could build one on your PCBs first before designing my own reference mini-module. I'll PM you.
I think we should introduce this bbs.38hot.net tradition here at the eevblog forum :) So far I managed to buy some 2DW233 thanks to technix's group buy initiative.
BTW This box of Vishays is a small fortune :)
  • Country: hk
« Reply #23 on: July 08, 2017, 05:17:25 am »
yes
0.01℃
The following users thanked this post: lukier, CalMachine
Offline d-smes
« Reply #24 on: July 08, 2017, 10:08:20 pm »
Mhm,
with best regards
Andreas
Andreas-  You are quite right.  According to schematic, H and L LEDs are overload indicators that trigger at +/- 2.6V or so.  Since first stage gain = 100, that says input noise is >26 mV.  Assuming, of course, that noise amplifier was connected when picture was taken.
