I've also decided to use an ADA4522-2, in my case for a DC servo amplifier stage. It has a good combination of low offset voltage, low bias current, and low 1/f noise. To thoroughly optimize this, I made a spreadsheet of the various candidates, and then plugged in some of my circuit's component values to be able to sort on the chip's performance in my circuit. For example, knowing the circuit resistances allows me to combine the bias current and voltage offset specs to get a total offset value that can be more easily sorted. I then created a 'feature vector' scoring system to weigh the remaining features - specs like distortion, 1/f noise, cost, etc. against each other to determine a figure of merit that could also be used to sort the candidates.
Long and short, different circuits can have different requirements, so what's ideal for one use may not be ideal for another. So, while we both like the ADA4522-2, I think it's worth the effort to build a table of the basic specs and then incorporate your own figure of merit calculations to see which parts objectively perform best in your circuit.
