Hello 001 and Kleinstein,
what burden voltage is ok for panel ampermeter?
the question ist incomplete. You do not mention the intended current range to be measured.
Furthermore you should consider how far a voltage drop on the panel meter affects your device unter test.
You might want to try this out measuring the start-up current on a 2,5'' harddrive - don't have a better example in mind.
IFAIK there is no real standard. Values of around 50 mV are good for higher current. With small currents something like 200 mV was very common with digital ones, the analog ones tend to have a little lower burden.
What is "high current", what is "low current" in quantitative terms?
Regards
try
