They are all soldered from the factory - so if there are sockets someone else has been in there previously.
Thanks for clarifying.
1. As you did not put a socket in by yourself, its probably still soldered in.
No I have not opened this device yet, but I'm pretty sure it's the old version.
2. Desoldering is very easy, but make sure first, that you really have the old version. A desoldering station is recommended. Pins are smaller than the holes, so no problem.
Often desoldering iron tips has same outer diameter of the lands ("Lötaugen") on the PCB, and when you move the tip a bit, it can contact/short the neighbour land.
3. It's really necessary to read out the CalRam content via GPIB first.
This was my plan.
4. Shorting is not the problem, because w/o operating voltage, the chip should be inoperative and immune, but obviously the heat is a problem. There are examples, where the Ram was OK, but failed directly after Desoldering.
Interesting, because the tracks of the leadframe are not very short for DIL24/28 packages.
5. Read the Ram after desoldering and compare.
That's a good idea, I will do so.
Can I stock the unsoldered NVRAMs sitting in conductible ESD foam without discharging the internal battery?
