I wanted the board to be used as a replacement for three different types of memory.
1. Dual CE Ram JMP1,JMP2-> pos 2. R1,R2 are installed as pullups. R3 not installed. IC2 installed.
2. DS1225 JMP1->pos1 JMP2->nc R1,R2 are installed. R3 not installed. IC2 not installed.
3. DS1230 JMP1,JMP2->pos 1. R1,R2 are not installed. R3 is installed. IC2 not installed.
JMP1 and JMP2 are zero ohm. I used 4.7k on R1,R2. R3 is zero ohm. I should have labeled it a jumper. IC2 is a 74LS00.
R1 and R2 tie the unused address lines high. An alternative design could use a two way switch between VCC and gnd for A13 and A14 for multiple backups.
JMP3 was originally added for in-circuit reading but I decided to just use a wire. I have the additional board for my EPROM programmer that seems to work fine.
The FM1808 can be substituted for cheaper lower capacity FRAM with the additional savings of R1&R2. Any future boards for my Datron products will use the cheaper FRAM.
