Author Topic: [AVR GCC] Error called object is not a function or function pointer  (Read 12252 times)
Offline sokoloff
Re: [AVR GCC] Error called object is not a function or function pointer
« Reply #25 on: August 21, 2018, 03:11:08 pm »
If I had a dollar for every time I've fixed someones code simply by moving the // comment in a #define to the line before.
You wouldn't earn a single dollar.
On any C99-or-later conforming compiler... C99 is the first version of the C standard that clarified how those comments where to be handled in the pre-processor phase.
Before that, I could certainly believe that early cfront implementations (the original C++ to C preprocessor) or any C pre-processor that didn't understand "//" but where the subsequent compiler did could have exhibited such behavior.
Offline sokoloff
« Reply #26 on: August 21, 2018, 03:20:27 pm »
I'm sorry but for years people have put in their code some register anded and ored to set certain bits with a numerical value. I put it behind a macro and now that number has to be a constant??? what the fuck are you all on about???? jesus christ! you want me to either create a constant whoes name if generic will be erm... let me think.... the number it represents and if i do them specific I'll just be making multiple constants that have the same values....
Indeed, coding is a sodding religion!!!!!!!!!!!!!!!!!!
You have demonstrated numerous times that you don't yet fully understand some pretty fundamental concepts in C (e.g. integer promotion, const values etc.), so why do you feel qualified to criticise both the language and peoples advice on how to use it?
ORing a value with zero is pointless.  Even though the optimiser should strip it out it adds nothing to the readability of your code and arguably detracts from it, so why do it?
I disagree. It tells me, as a reader of the code, that the author consciously is not setting those bits (as opposed to simply having forgotten or made a copy/paste error).
I'd be inclined towards a variant of the code as below, assuming you are using a C++14 or later compiler (which supports the 0b/0B notation as part of the language spec).
// CNTMODE[2:0] Timer Mode Writing these bits selects the Timer mode
#define TCB0_TIMER_MODE_MASK 0b00000111
#define TCB0_SET_TIMER_MODE_PERIODIC_INTERRUPT   TCB0.CTRLB = ((TCB0.CTRLB & (^TCB0_TIMER_MODE_MASK)) | 0b000)
#define TCB0_SET_TIMER_MODE_TIME_OUT_CHECK       TCB0.CTRLB = ((TCB0.CTRLB & (^TCB0_TIMER_MODE_MASK)) | 0b001)
#define TCB0_SET_TIMER_MODE_EVENT                TCB0.CTRLB = ((TCB0.CTRLB & (^TCB0_TIMER_MODE_MASK)) | 0b010)
#define TCB0_SET_TIMER_MODE_FREQ_MEASUREMENT     TCB0.CTRLB = ((TCB0.CTRLB & (^TCB0_TIMER_MODE_MASK)) | 0b011)
#define TCB0_SET_TIMER_MODE_PW_MEASUREMENT       TCB0.CTRLB = ((TCB0.CTRLB & (^TCB0_TIMER_MODE_MASK)) | 0b100)
#define TCB0_SET_TIMER_MODE_FREQ_PW_MEASUREMENT  TCB0.CTRLB = ((TCB0.CTRLB & (^TCB0_TIMER_MODE_MASK)) | 0b101)
#define TCB0_SET_TIMER_MODE_SINGLE_SHOT          TCB0.CTRLB = ((TCB0.CTRLB & (^TCB0_TIMER_MODE_MASK)) | 0b110)
#define TCB0_SET_TIMER_MODE_8BIT_PWM             TCB0.CTRLB = ((TCB0.CTRLB & (^TCB0_TIMER_MODE_MASK)) | 0b111)
Offline sokoloff
« Reply #27 on: August 21, 2018, 03:23:21 pm »
C++14 compiler support for 0b literals is fairly common nowadays:
https://en.cppreference.com/w/cpp/compiler_support#cpp14
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #28 on: August 21, 2018, 05:06:03 pm »
what a "too clever" kid will answer to his father's advice? well in this case the OP is not a kid and i guess its just because he doesnt need it, i should have sticked with my 1st reply, instead i got trolled by the later poster :-DD let the OP play with his new toy peacefully. (ps: i lately tend to delete my posts before someone else do, which are not relevant to the topic or pose less interest, it will not add value to my post count and hence is a shame ;D)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« Reply #29 on: August 21, 2018, 05:18:54 pm »
You said you'd need to define 2^8 symbols for every register value but this isn't true for typical peripherals that use one or more bits per register to control specific functions.  You define symbols for each function in the register and then OR them together.  Usually these are already defined for you in a target specific header that comes with the compiler.  This way someone reading your code can see what it's doing without having to decode "magic" numbers.
Also using binary notation is not a good idea, this is a specific GCC extension and not supported by many/most compilers.  Use hex notation in these cases, it's very easy to mentally convert this to a binary sequence and is standard C.
Granted i am a novice but DDRB = a load of math is commonly seen, why do I suddenly need to make these values into indescribable variables?. I need to write several bits in a register at one time, these values of interest can be several bits long starting and ending anywhere and of and any combination therefor there are numerous combinations. I really don't get it, what I am being told makes no sense in this regard and I have never seen it done before.
I was not aware that binary was GCC specific. Given that we are talking about individual bit positions in a register binary is the mos readable format that relates directly to the datasheet. All i am doing is trying to convert a statement like "TCB0.CTRLB = ((TCB0.CTRLB & 0b11111000) | 0b00000010)" into something meaningful, it is being done by simple copy and pasting by the preprocessor and is the only way i can think of programming without restudying the datasheet every time I need to change something ore write something new. I am even using the datasheet's own definitions and names to make it even easier to find what the hell i was on about in the datasheet. Yes the first statement in the list is semi nonsensical but does no harm and works, the problem exactly was ?
Offline NorthGuy
« Reply #30 on: August 21, 2018, 06:43:03 pm »
I personally don't like copy and paste, so I try to avoid it. Otherwise I misspell something and then I need to correct the mistake in every re-incarnation of whatever I copied and pasted. It's not always possible to avoid copying and pasting, but it is possible, to some extent, here. So, if I ever wanted to do the same as OP, I would do:
#define TCB0_MODE(v) TCB0.CTRLB = ((TCB0.CTRLB & 0xf8) | (v))
#define TCB0_MODE_PERIODIC_INTERRUPT TCB0_MODE(0)
#define TCB0_MODE_TIME_OUT_CHECK TCB0_MODE(1)
Also, if I ever wanted to change what I've done, I would need to change it in only one place, for example
#define TCB0_MODE(v) TCB0.CTRLB ^= (TCB0.CTRLB ^ (v)) & 0x07
Offline sokoloff
« Reply #31 on: August 21, 2018, 06:47:04 pm »
It's not. It was previously an extension to the language, supported early on by gcc and others, but became part of the C++14 standard.
  • Global Moderator
« Reply #32 on: August 21, 2018, 06:51:07 pm »
So I define it once in my standard header file, make sure it is correct and then copy and paste my human readable defines into the code. This is easier to get right. If i make a code error I correct the code in one place and the correction is carried through by the next preprocessor.
Ultimately you can correct mistakes with find and replace in most programs, atmel studio will do it on the entire project/solution if needs be.
  • Global Moderator
« Reply #33 on: August 21, 2018, 06:51:34 pm »
So I am doing good after all!
Offline Nusa
« Reply #34 on: August 21, 2018, 07:45:28 pm »
One of my rules for writing portable code is never put a comment on the same line as a #define. True, it won't bite you 99.9% of the time, but finding those 0.1% problems makes up for it!
Could you show a single example of how this can cause a problem?
Sure. Here's a link to a real-live example that broke when the Arduino preprocessor was changed in 2016 (I'm known as Eric on that forum).
http://forum.seemecnc.com/viewtopic.php?f=99&t=10268&p=91408&hilit=comment#p91407
The define in question is:
#define Z_PROBE_PIN 16 // mini-rambo ext pins on P3 ext next to LCD header
The fix was:
Technically this would work too, but would get broken the next time someone OCD about formatting touched the code:
#define Z_PROBE_PIN 16// mini-rambo ext pins on P3 ext next to LCD header
You have to remember these are strings, not numbers. Does it expand to "16" or "16 "? Most of the time it doesn't matter. This is one of those cases where it does. The rest of the story is found in the macros that translate the arduino logical pin number to the physical pin identifier. The macro _READ() is invoked by the macro READ(Z_PROBE_PIN) and is found in a file named fastio.h:
This code contibuted by Triffid_Hunter and modified by Kliment
why double up on these macros? see http://gcc.gnu.org/onlinedocs/cpp/Stringification.html
        2012/3/10 AT90USB128x modified by lincomatic to match Teensyduino
#ifndef _ARDUINO_H
#define _ARDUINO_H
#include <avr/io.h>
utility functions
#ifndef MASK
/// MASKING- returns \f$2^PIN\f$
#define MASK(PIN) (1 << PIN)
#endif
magic I/O routines
now you can simply SET_OUTPUT(STEP); WRITE(STEP, 1); WRITE(STEP, 0);
/// Read a pin
#define _READ(IO) ((bool)(DIO ## IO ## _RPORT & MASK(DIO ## IO ## _PIN)))
/// write to a pin
#define _WRITE(IO, v) do { if (v) {DIO ##  IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ##  IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0)
/// toggle a pin
#define _TOGGLE(IO) do {DIO ##  IO ## _RPORT = MASK(DIO ## IO ## _PIN); } while (0)
/// set pin as input
#define _SET_INPUT(IO) do {DIO ##  IO ## _DDR &= ~MASK(DIO ## IO ## _PIN); } while (0)
/// set pin as output
#define _SET_OUTPUT(IO) do {DIO ##  IO ## _DDR |=  MASK(DIO ## IO ## _PIN); } while (0)
/// check if pin is an input
#define _GET_INPUT(IO) ((DIO ## IO ## _DDR & MASK(DIO ## IO ## _PIN)) == 0)
/// check if pin is an output
#define _GET_OUTPUT(IO) ((DIO ## IO ## _DDR & MASK(DIO ## IO ## _PIN)) != 0)
// why double up on these macros? see http://gcc.gnu.org/onlinedocs/cpp/Stringification.html
/// Read a pin wrapper
#define READ(IO) _READ(IO)
/// Write to a pin wrapper
#define WRITE(IO, v) _WRITE(IO, v)
#define     PULLUP(IO,v)            _WRITE(IO, v)
/// toggle a pin wrapper
#define TOGGLE(IO) _TOGGLE(IO)
/// set pin as input wrapper
#define SET_INPUT(IO) _SET_INPUT(IO)
/// set pin as output wrapper
#define SET_OUTPUT(IO) _SET_OUTPUT(IO)
/// check if pin is an input wrapper
#define GET_INPUT(IO) _GET_INPUT(IO)
/// check if pin is an output wrapper
#define GET_OUTPUT(IO) _GET_OUTPUT(IO)
ports and functions
added as necessary or if I feel like it- not a comprehensive list!
#if defined (__AVR_ATmega168__) || defined (__AVR_ATmega328__) || defined (__AVR_ATmega328P__)
// UART
#define RXD DIO0
#define TXD DIO1
// SPI
#define SCK 13
#define MISO DIO12
#define MOSI DIO11
#define SS 10
// TWI (I2C)
#define SCL AIO5
#define SDA AIO4
// timers and PWM
#define OC0A DIO6
#define OC0B DIO5
#define OC1A DIO9
#define OC1B DIO10
#define OC2A DIO11
#define OC2B DIO3
#define DEBUG_LED AIO5
pins
#define DIO0_PIN PIND0
#define DIO0_RPORT PIND
#define DIO0_WPORT PORTD
#define DIO0_DDR DDRD
#define DIO0_PWM NULL
#define DIO1_PIN PIND1
#define DIO1_RPORT PIND
#define DIO1_WPORT PORTD
#define DIO1_DDR DDRD
#define DIO1_PWM NULL
#define DIO2_PIN PIND2
#define DIO2_RPORT PIND
#define DIO2_WPORT PORTD
#define DIO2_DDR DDRD
#define DIO2_PWM NULL
#define DIO3_PIN PIND3
#define DIO3_RPORT PIND
#define DIO3_WPORT PORTD
#define DIO3_DDR DDRD
#define DIO3_PWM &OCR2B
///* SNIP....you get the idea, and the file is way too long to copy here anyway */
  • Global Moderator
« Reply #35 on: August 21, 2018, 07:55:48 pm »
except I do not try to write code with macros or setup any conditions. I simply use them as text replacement tools to make code more readable or to define a constant where the "cosnt" assignment fails.
If you took all of the code behind my macros and put that in the c code instead it would be the same thing.
Offline Nusa
« Reply #36 on: August 21, 2018, 08:12:32 pm »
I've been getting paid for code since 1973, so I've lived the entire era where the preprocessor didn't support it, while the compiler did. And yes, it's certainly possible some of my personal rules are a bit obsolete, but they have served me well.
This particular rule still has some value, as I just demonstrated in my previous response.
Offline sokoloff
« Reply #37 on: August 21, 2018, 08:20:05 pm »
Completely understand.
I was trying to support your point. It seems like I may not have succeeded...
Offline NorthGuy
« Reply #38 on: August 21, 2018, 10:13:41 pm »
It expands to "16". It is tokenized before pre-processing. Pre-processor operates on tokens.
The problem here is not the use of comments, but the use of buggy pre-processors/compilers.
Either this
READ(Z_PROBE_PIN)
or this
READ(Z_PROBE_PIN)
expands to this:
((bool)(DIO16_RPORT & (1 << DIO16_PIN)))
If your tools don't have bugs that is.
If you have open source tools, rather than adhering to their bugs, you better fix the tools.
« Last Edit: August 21, 2018, 10:16:31 pm by NorthGuy »
Offline cv007
« Reply #39 on: August 21, 2018, 10:34:01 pm »
you can even take it further since you have more than one of the same timer-
#define TCB_MODE(n,v) TCB##n##.CTRLB = ((TCB##n##.CTRLB & 0xf8) | (v))
now you have a generic for every timer b
TCB_MODE(0, 0)
TCB_MODE(1, 0)
(you would even get an error if n was an invalid number)
but it is endless when it comes to defines/macros, and you end up with another language to maintain where you use the manufacturers defines/macros, your own defines/macros, and ultimately the functions which will use a combination of both
not trying to throw wrenches into gears, but maybe consider just using functions to do the work
a simple example using the avr defines already provided, and turning the mode setting into a function-
//just to make sure using a valid timer number
//(there could already be something in the avr include for this, I don't know)
typedef enum { TCBn0, TCBn1, TCBn2, TCBn3 } TCBn_t;
//simple function
//if we want to know what some of these defines are- look in one file- iom4809.h
//this function and iom4809.h are all we need to see how this function works
TCBmode(TCBn_t n, TCB_CNTMODE_t mode){
     TCB0[n].CTRLB = (TCB0[n].CTRLB & (TCB_CNTMODE_gm<<TCB_CNTMODE_gp)) | mode;
//usage- it looks like a function, and it is a function
TCBmode( TCBn0 ,TCB_CNTMODE_TIMEOUT_gc );
//compare to
TCB0_MODE_TIME_OUT_CHECK;
//or
SET_TCB0_MODE(TCB0_MODE_TIME_OUT_CHECK);
//or
TCB_MODE(0, TCB0_MODE_TIME_OUT_CHECK);
//or any other type of macro/define
//AND_IT_ENDS_UP_LOOKING_LIKE_THIS_EVERYWHERE_FOR_EVERYTHING & WHICH_IS_HARD_TO_READ & DECIPHER
I know every last byte wants to be squeezed out of a micro, but compilers are good at removing unused code, in-lining, etc.,  and in many cases the defines/macros are not worth the trouble when a function will do the job with little cost and where readability/reliability becomes much better (in my opinion).
I'll go crawl back into my hole in the ground.
Offline andyturk
« Reply #40 on: August 21, 2018, 10:53:25 pm »
If you have open source crappy proprietary tools, rather than adhering to their bugs, you better fix the tools (or find a better mcu).
FTFY.
Offline NorthGuy
« Reply #41 on: August 21, 2018, 11:27:06 pm »
FTFY.
I don't understand your communication, but I do consider it impolite to present your own stuff as if it was said by me. I didn't say what you have quoted, nor anything remotely similar.
Offline Nusa
« Reply #42 on: August 22, 2018, 05:24:13 am »
Nonetheless, I provided you with the ONE example you asked for. Just because it worked it in your own personal environment doesn't mean it wasn't a real problem for real people in real lives that needed real solutions right now.
Remember, I said this is one of my "rules for writing portable code". I have to write for the world that exists, not the world that is perfect. This is a detail that, in the real world, has never been implemented consistently between implementations. I've already proved that. A simple habit avoids the problem entirely, so that's the way I go. And if someone takes some of my code to a new platform 10 years from now and it still works, I've done my job correctly.
P.S. No charge, but it would be nice if you sent me a dollar anyway.
  • Global Moderator
« Reply #43 on: August 22, 2018, 06:20:50 am »
TCB_MODE(0, 0)
TCB_MODE(1, 0)
//simple function
//compare to
//or
//or
And I have no intention of going to such extremes, why bother? it becomes a new language. I write everything for TCB0 and then do a text replacement for the other timers, simple, fast. That is all more robust and I'm not using macro's to create code but simply replace text making my code readable. I am indeed considering writing some functions but at the end of the day they will still have the macros in them so that if i ever want to be reminded of what that code does it's easy.
Offline NorthGuy
« Reply #44 on: August 22, 2018, 01:54:05 pm »
You cannot predict what compiler bugs you may encounter. No matter what you rules are, you cannot make sure that future bugs don't affect you.
I have encountered compiler bugs in the past. This is certainly not an easy thing to deal with. However, it would be silly if I decided to change my programming habits to work around compiler bugs.
Why me?
Offline sokoloff
« Reply #45 on: August 22, 2018, 03:56:31 pm »
Why me?
Presumably referencing this:
The following users thanked this post: andyturk, Nusa
Offline andyturk
« Reply #46 on: August 22, 2018, 04:54:01 pm »
FTFY.
FTFY means "Fixed That For You". I.e., I disagreed with your statement and made a snarky edit as a demonstration. I don't consider that impolite really, so perhaps we disagree on that as well.
Welcome to the internet.
Offline NorthGuy
« Reply #47 on: August 22, 2018, 05:27:04 pm »
You didn't disagree with my statement. You disagreed with your personal interpretation of my statement. That is exactly why quoting should be exact. Here's what I said:
If you want to make this into comparison with proprietary tools (which it is not), it's much simpler:
- If you have proprietary tools you have to live with their bugs.
- If you have open source tools, rather than adhering to their bugs, you better fix the tools.
What a lame excuse. Internet is not in the parallel virtual universe where nothing matters any more. Other participants are not robots, but human beings.
Offline andyturk
« Reply #48 on: August 22, 2018, 06:04:49 pm »
What? Are you trying to start a food fight?  :popcorn:
Well sure, if it's an important conversation about technical stuff. But you made a (possibly snarky?) comment about open source tools and I made a (definitely snarky!) reply. Sigh.
Quote from: NorthGuy
Agreed. Sorry if my posts offended.
FWIW, you do know your stuff and I actually look for threads where you participate, since there's often good material to be found... especially when it comes to the C preprocessor!
EDIT: "posts"
Offline NorthGuy
« Reply #49 on: August 23, 2018, 03:46:29 am »
Of course not. Bad peace is better than a good war.
