I have a coordinator and 7 routers all connected on the same network.
I have 4 more router devices to connect.
I am able to connect them, but after few seconds, they leave the network (not sure yet if they leave on their own or if they are kicked out).
To make a test, I reset everything (coordinator and routers to factory defaults).
I associated routers to the network again, this time by trying to make the one that left the network to join first.
They joined without any issue.
Eventually, I ended up with 1 coordinator and 7 routers connected.
When I tried to connect my 8th router device to the network, I saw it join, then leave the network.
It seems there is some sort of configuration that prevents me from adding more than 7 routers to my network.
Any idea why?
What parameters should I tweak to fix the issue?
I wish to be able to add up to 19 routers to my network.
