Author Topic: [PIC32] Mikroelektronika Mini-32 Problem  (Read 7202 times)
Offline N3xusTopic starter
  • Country: at
« on: July 22, 2016, 09:25:48 pm »
Hello all.
Some days ago I bought a MINI-32 from Mikroelektronika.
Here a link to the data sheet: http://download.mikroe.com/documents/starter-boards/mini/pic32/mini-32-manual-v101.pdf
The problem I have is that I am not able to get it working using the boot loader of Mikroelektronika.
Unfortunately they do not offer any support if I do not use their compiler.
Here the source code I was trying to implement:
// disable PLIB warning
#define _SUPPRESS_PLIB_WARNING
//#include <XC.h>
#include <plib.h>
#include <p32xxxx.h>
//Configuration Bits
#pragma config FSOSCEN = OFF // Disable secondary oscillator
#pragma config POSCMOD=HS // High speed crystal mode
#pragma config FNOSC=PRIPLL // Use Primary Oscillator with PLL (XT, HS, or EC)
#pragma config FPLLIDIV = DIV_2 // Divide 8MHz to between 4-5MHz before PLL (now 4MHz)
#pragma config FPLLMUL=MUL_20 // Multiply with PLL (now 80MHz)
#pragma config FPLLODIV=DIV_1 // divide by 1
#pragma config FWDTEN = OFF // Disable watchdog timer
#define SYSCLK 80000000UL
int main(void) {
    SYSTEMConfigPerformance(SYSCLK);
    TRISDbits.TRISD6 = 0;
    LATDbits.LATD6 = 1;
    TRISGbits.TRISG6 = 0;
    LATGbits.LATG6 = 0;
    while(1)
    return (1);
When I compile the code and upload it to the board nothing happens. Both LED's stay off.
I also tried to set it up using MPLAB Harmony which also led to no results.
Does somebody of you have any clue about the problem I am facing?
BTW. the example .hex file supplied by Mikroelektronika works without problems and so there seems to be no problem with the µC.
Regards
Armin
Offline dannyf
Re: [PIC32] Mikroelektronika Mini-32 Problem
« Reply #1 on: July 22, 2016, 10:33:16 pm »
Seems to me the natural course of action in this case would be to use their software (demo or otherwise) to compile a proven piece of code (their own sample code for example) into a hex file (or to get a proven working hex file from a proven / reliable source) and flash it to your chip.
As of now, you have too many unknowns for you to pinpoint the issue. You need to narrow that down.
  • Country: at
« Reply #2 on: July 23, 2016, 07:26:02 am »
Maybe that's a good idea. I will try it this afternoon. Thanks so far.
Gesendet von iPhone mit Tapatalk
  • Country: at
« Reply #3 on: July 23, 2016, 01:05:42 pm »
Ok, I know recognised that it doesn't work with their software either. I assume that there are configuration issues. I will try to ask them for help directly again.
Offline dannyf
« Reply #4 on: July 23, 2016, 01:49:46 pm »
Generally, the issues are with configuration bits and alternative functions on gpio pins. The typical process is to use the simplest configuration (internal rc, no pll, etc.) and disable any non-gpio function on pins and flip them.
I posted a series of "getting started on ..." posts on my blog and here is the one for pic32: https://dannyelectronics.wordpress.com/2016/04/24/getting-started-on-pic32-mplab-xpickit2/
It uses a different processor but the basic idea is the same.
  • Country: at
« Reply #5 on: July 23, 2016, 05:45:58 pm »
Well, generally I would agree with you but this is not possible with this board.
There is a preloaded bootloader that seems to define the configuration bits. So as I assume the configuration bits written in the software will not have any influence. I got this as answer on the MikroElektronika Forum. Furthermore, I do not have a programmer by now because otherwise it would be no problem to program the PIC.
Nevertheless, thank you for sharing the Link.
  • Country: at
« Reply #6 on: July 23, 2016, 07:14:46 pm »
FYI the link to the MikroElektronika Forum where I posted my question: http://forum.mikroe.com/viewtopic.php?f=12&t=68103&p=273338#p273338
I got it working in their IDE with their compiler but the same software do not run with MPLAB. As I wrote in the other Forum I think I will give up and switch to a programmer or completely switch platform.
Offline dannyf
« Reply #7 on: July 23, 2016, 07:59:59 pm »
It is highly unlikely that they got the programming software fully integrated into the IDE.
So if you can find their programming software that takes a .hex file, you can pretty much use any IDE that produces the .hex file.
Again, common sense dictates that you try to reduce the unknowns in a process to help pin point your issues.
  • Country: at
« Reply #8 on: July 23, 2016, 08:24:05 pm »
You are right, the "programmer" is a separate tool supplied by them.
Some clarification:
Method 1:
Project compiled with MikroC (Compiler from Mikroelektronika)
Uploaded to the µC via the supplied tool -> µC works as it should.
Project compiled with MPLAB
Uploaded to the µC with the same tool as before -> µC does not do anything.
So I must assume that there is any problem with MPLAB. I think that there is any setting in MPLAB I am missing to get this thing up and running but I scanned through all settings and cannot find anything plausible. BTW I used the same configuration bits as in the MikroC version.
Offline Kilrah
« Reply #9 on: July 23, 2016, 08:29:57 pm »
Are the libraries, definitions etc identical for both? Most likely not, you often can't just copy/paste the code form one compiler suite to the other.
  • Country: at
« Reply #10 on: July 23, 2016, 08:39:43 pm »
No, they are not the same because the compilers are different. But I adapted all lines to the other compiler which also compiled without errors or warnings.
I now tried out the simulator in MPLAB and saw that the Port value changes as expected. So there must be any problem when the .hex file is created...
Offline Kilrah
« Reply #11 on: July 23, 2016, 08:45:23 pm »
Is there any doc about the bootloader? It might require relocating the code in memory for proper operation.
Offline dannyf
« Reply #12 on: July 23, 2016, 08:50:40 pm »
try to download the following two .hex files to the chip and see what happens:
hex file 1
:020000040000fa
:020000041fc01b
:042ff000ffffff3fa1
:020000040000fa
:020000041fc01b
:042ff40099fff9ff49
:020000040000fa
:020000041fc01b
:042ff80058ceefffc1
:020000040000fa
:020000041fc01b
:042ffc00ffffff7f55
:020000040000fa
:020000041fc01b
:1000000000601a40c0045a7f050040130000000041
:10001000009d1a3ce4035a2708004003000000003a
:1000200000a01d3cf83fbd2700a01c3cf07f9c2792
:1000300002600940205820018449497d02608940be
:10004000c000000000e0dc4102608b40009d083ce5
:100050000c04082509f800010000000000a0083c7d
:100060000000082500a0093c00002925060000101a
:1000700000000000000000ad040000ad080000ad6d
:100080000c0000ad100008252b080901f9ff201411
:1000900000000000009d083cfc0308250000098dbd
:1000a000180020110400082500000a8d040008250e
:1000b00000000b8d090060110400082500000c9160
:1000c000ffff4a250100082500002ca1fbff401579
:1000d000010029250500001000000000000020a1fb
:1000e000ffff4a25fdff40150100292503000825d3
:1000f000fcff0a24244048010000098de7ff201579
:10010000000000000000093c00002925100020111b
:10011000000000000000093c0040292588bf0a3c7f
:1001200010204a25000049ad0000093c0040292567
:1001300088bf0a3c20204a25000049ad0000093c48
:100140000040292588bf0a3c30204a25000049addf
:1001500000488040ffff0a2400588a40c09f093ca5
:1001600000102925017889400000093c010029255b
:1001700000000a2444492a7d01608a408000093c2d
:1001800000688940008008408005097d404c0900d6
:10019000006008405800013c24400101254028012e
:1001a00000608840009d083c1404082509f80001ff
:1001b0000000000000600840bfff013cffff213449
:1001c0002440010100608840000084300000a53018
:1001d000009d083c74020825080000010000000092
:020000040000fa
:020000041fc01b
:10038000009d1a3c44035a27080040030000000067
:020000040000fa
:020000041fc01b
:10118000009d1a3c28015a27080040030000000077
:020000040000fa
:020000041fc01b
:08120000ed00400b00000000ae
:020000040000fa
:020000041fc01b
:08122000ed00400b000000008e
:020000040000fa
:020000041fc01b
:08124000ed00400b000000006e
:020000040000fa
:020000041fc01b
:08126000ed00400b000000004e
:020000040000fa
:020000041fc01b
:08128000ed00400b000000002e
:020000040000fa
:020000041fc01b
:0812a000ed00400b000000000e
:020000040000fa
:020000041fc01b
:0812c000ed00400b00000000ee
:020000040000fa
:020000041fc01b
:0812e000ed00400b00000000ce
:020000040000fa
:020000041fc01b
:08130000ed00400b00000000ad
:020000040000fa
:020000041fc01b
:08132000ed00400b000000008d
:020000040000fa
:020000041fc01b
:08134000ed00400b000000006d
:020000040000fa
:020000041fc01b
:08136000ed00400b000000004d
:020000040000fa
:020000041fc01b
:08138000ed00400b000000002d
:020000040000fa
:020000041fc01b
:0813a000ed00400b000000000d
:020000040000fa
:020000041fc01b
:0813c000ed00400b00000000ed
:020000040000fa
:020000041fc01b
:0813e000ed00400b00000000cd
:020000040000fa
:020000041fc01b
:08140000ed00400b00000000ac
:020000040000fa
:020000041fc01b
:08142000ed00400b000000008c
:020000040000fa
:020000041fc01b
:08144000ed00400b000000006c
:020000040000fa
:020000041fc01b
:08146000ed00400b000000004c
:020000040000fa
:020000041fc01b
:08148000ed00400b000000002c
:020000040000fa
:020000041fc01b
:0814a000ed00400b000000000c
:020000040000fa
:020000041fc01b
:0814c000ed00400b00000000ec
:020000040000fa
:020000041fc01b
:0814e000ed00400b00000000cc
:020000040000fa
:020000041fc01b
:08150000ed00400b00000000ab
:020000040000fa
:020000041fc01b
:08152000ed00400b000000008b
:020000040000fa
:020000041fc01b
:08154000ed00400b000000006b
:020000040000fa
:020000041fc01b
:08156000ed00400b000000004b
:020000040000fa
:020000041fc01b
:08158000ed00400b000000002b
:020000040000fa
:020000041fc01b
:0815a000ed00400b000000000b
:020000040000fa
:020000041fc01b
:0815c000ed00400b00000000eb
:020000040000fa
:020000041fc01b
:0815e000ed00400b00000000cb
:020000040000fa
:020000041fc01b
:08160000ed00400b00000000aa
:020000040000fa
:020000041fc01b
:08162000ed00400b000000008a
:020000040000fa
:020000041fc01b
:08164000ed00400b000000006a
:020000040000fa
:020000041fc01b
:08166000ed00400b000000004a
:020000040000fa
:020000041fc01b
:08168000ed00400b000000002a
:020000040000fa
:020000041fc01b
:0816a000ed00400b000000000a
:020000040000fa
:020000041fc01b
:0816c000ed00400b00000000ea
:020000040000fa
:020000041fc01b
:0816e000ed00400b00000000ca
:020000040000fa
:020000041fc01b
:08170000ed00400b00000000a9
:020000040000fa
:020000041fc01b
:08172000ed00400b0000000089
:020000040000fa
:020000041fc01b
:08174000ed00400b0000000069
:020000040000fa
:020000041fc01b
:08176000ed00400b0000000049
:020000040000fa
:020000041fc01b
:08178000ed00400b0000000029
:020000040000fa
:020000041fc01b
:0817a000ed00400b0000000009
:020000040000fa
:020000041fc01b
:0817c000ed00400b00000000e9
:020000040000fa
:020000041fc01b
:0817e000ed00400b00000000c9
:020000040000fa
:020000041fc01b
:08180000ed00400b00000000a8
:020000040000fa
:020000041fc01b
:08182000ed00400b0000000088
:020000040000fa
:020000041fc01b
:08184000ed00400b0000000068
:020000040000fa
:020000041fc01b
:08186000ed00400b0000000048
:020000040000fa
:020000041fc01b
:08188000ed00400b0000000028
:020000040000fa
:020000041fc01b
:0818a000ed00400b0000000008
:020000040000fa
:020000041fc01b
:0818c000ed00400b00000000e8
:020000040000fa
:020000041fc01b
:0818e000ed00400b00000000c8
:020000040000fa
:020000041fc01b
:08190000ed00400b00000000a7
:020000040000fa
:020000041fc01b
:08192000ed00400b0000000087
:020000040000fa
:020000041fc01b
:08194000ed00400b0000000067
:020000040000fa
:020000041fc01b
:08196000ed00400b0000000047
:020000040000fa
:020000041fc01b
:08198000ed00400b0000000027
:020000040000fa
:020000041fc01b
:0819a000ed00400b0000000007
:020000040000fa
:020000041fc01b
:0819c000ed00400b00000000e7
:020000040000fa
:020000041fc01b
:0819e000ed00400b00000000c7
:020000040000fa
:020000041fc01b
:1004800000f89b40c0000000009d1b3cc0027b2781
:1004900000c09b4000f81b40c00000001f0000424d
:0404a0000000000058
:020000040000fa
:020000041d00dd
:10000000f8ffbd270400beaf21f0a003211080003f
:100010000700400b0800c2a3400000000800c29384
:100020002b100200ff0042300800c393ffff63243f
:10003000f9ff40140800c3a321e8c0030400be8fe9
:100040000800e0030800bd27e8ffbd271400bfaf8c
:100050001000beaf21f0a0031800c4af1800c28f7b
:10006000ff004230212040000000400f000000004f
:100070001800c28f021202001800c2af2400400b09
:1000800000000000ff0004240000400f00000000fa
:100090001800c28f2b100200ff0042301800c38fdf
:1000a000ffff63241800c3aff6ff401400000000f8
:1000b00021e8c0031400bf8f1000be8f1800bd27b9
:1000c0000800e00300000000e8ffbd271400bfaff8
:1000d0001000beaf21f0a0031800c4af3c00400bdd
:1000e00000000000c00304241200400f00000000c4
:1000f0001800c28f2b100200ff0042301800c38f7f
:10010000ffff63241800c3aff6ff40140000000097
:1001100021e8c0031400bf8f1000be8f1800bd2758
:080120000800e00300000000ec
:020000040000fa
:020000041d00dd
:10012800a8ffbd270400a1af0800a2af0c00a3af31
:100138001000a4af1400a5af1800a6af1c00a7af0d
:100148002000a8af2400a9af2800aaaf2c00abafad
:100158003000acaf3400adaf3800aeaf3c00afaf4d
:100168004000b8af4400b9af4800bfaf124000002c
:100178004c00a8af104000005000a8af009d1a3cea
:100188007c035a2700000000006804400060054016
:1001980009f84003000000005000a88f110000017a
:1001a8004c00a88f130000010400a18f0800a28f43
:1001b8000c00a38f1000a48f1400a58f1800a68f21
:1001c8001c00a78f2000a88f2400a98f2800aa8fc1
:1001d8002c00ab8f3000ac8f3400ad8f3800ae8f61
:1001e8003c00af8f4000b88f4400b98f4800bf8fe4
:0c01f8005800bd27c000000018000042a5
:020000040000fa
:020000041d00dd
:10020400e8ffbd271400bfaf1000beaf21f0a0036c
:10021400c100400f0000000088bf023ca061438c75
:1002240000ff02242418620088bf023ca06143ac92
:1002340088bf023c8061438c00ff022424186200c2
:1002440088bf023c806143ac88bf023ca061428c01
:10025400ff00433888bf023ca06143ac640004241f
:100264003200400f000000009300400b000000002b
:020000040000fa
:020000041d00dd
:100274000000043ce8ffbd27000084240300801034
:100284001400bfaf09f880000000000000008430b3
:100294000000a5308100400f000000000000023c77
:1002a40000004224030040100000000009f8400050
:0c02b40000000000f9ff00100000000036
:020000040000fa
:020000041d00dd
:1002c00000606041c000000099aa033c81bf023c6d
:1002d0005566632430f240ac30f243ac6655033cc3
:1002e000aa99633430f243ac81bf023c010003247d
:1002f00018f643ac81bf023c10f6428cb200400bb2
:1003000000000000f8ffbd270400beaf21f0a003ed
:1003100081bf023cffff0334609043ac88bf033cc5
:100320000010628c010004240463827c001062ac23
:1003300021e8c0030400be8f0800bd270800e003c9
:0403400000000000b9
:020000040000fa
:020000041d00dd
:100344000000023ce8ffbd270000422406004010e4
:100354001400bfaf0000023c000042240300401020
:10036400009d023c3f000070009d023cc0024224fc
:0803740009f840000000000040
:020000040000fa
:020000041d00dd
:10037c000000023ce8ffbd270000422406004010ac
:10038c001400bfaf0000023c0000422403004010e8
:10039c00009d023c3f000070009d023cc0024224c4
:0803ac0009f840000000000008
:020000040000fa
:020000041d00dd
:1003b4000000023c00004224050040100000023c02
:1003c4000000422403004010009d023c3f000070e6
:1003d400009d023cc002422409f8400000000000d5
:020000040000fa
:020000041d00dd
:1003e40000601a40bfff1b3cffff7b3724d05b0338
:0803f40000609a40180000426d
:020000040000fa
:020000041d00dd
:1003fc000000000022222222222222222222222259
:020000040000fa
:020000041d00dd
:08040c000800e00300000000fd
:020000040000fa
:020000041d00dd
:080414000800e00300000000f5
:00000001FF
hex file 2
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:020000040000fa
:020000041fc01b
:0404a0000000000058
:020000040000fa
:020000041d00dd
:020000040000fa
:020000041d00dd
:020000040000fa
:020000041d00dd
:020000040000fa
:020000041d00dd
:020000040000fa
:020000041d00dd
:0403400000000000b9
:020000040000fa
:020000041d00dd
:020000040000fa
:020000041d00dd
:020000040000fa
:020000041d00dd
:020000040000fa
:020000041d00dd
:020000040000fa
:020000041d00dd
:020000040000fa
:020000041d00dd
:020000040000fa
:020000041d00dd
:00000001FF
I think all the right points have been made earlier in the thread. You just need to follow them.
  • Country: at
« Reply #13 on: July 23, 2016, 09:01:03 pm »
attached you can find the information about the bootloader.
Unfortunately this is too much for me to understand... oO
It seems reasonable to me that there is any memory adress problem.
I tried both HEX files but did not get any response from the board. At least no LED's are turned on.
  • Country: at
« Reply #14 on: July 24, 2016, 07:04:07 am »
I think this output from MikroC could help. Am I right that this is the memory map of the program?
It is called "view listing" in the IDE. Is it correct that in this case my program must be located starting at address 0x9D000050 ?
;  LST file generated by mikroListExporter - v.2.0
; Date/Time: 23/07/2016 20:50:46
;Address Opcode         ASM
____SysVT:
0x9FC01180        0x0B400008  J        ___GenExcept
0x9FC01184        0x70000000  NOP
; end of ____SysVT
____BootVT:
0xBFC00380        0x3C1E9D00  LUI        R30, 40192
0xBFC00384        0x37DE0038  ORI        R30, R30, 56
0xBFC00388        0x03C00008  JR        R30
0xBFC0038C        0x70000000  NOP
; end of ____BootVT
_main:
;01_blinkLED.c, 1 ::                 void main() {
;01_blinkLED.c, 3 ::                 AD1PCFG = 0xFFFF;
0x9D000050        0x3402FFFF  ORI        R2, R0, 65535
0x9D000054        0x3C1EBF81  LUI        R30, 49025
0x9D000058        0xAFC29060  SW        R2, -28576(R30)
;01_blinkLED.c, 6 ::                 TRISG = 0;
0x9D00005C        0x3C1EBF88  LUI        R30, 49032
0x9D000060        0xAFC06180  SW        R0, 24960(R30)
;01_blinkLED.c, 7 ::                 TRISD = 0;
0x9D000064        0x3C1EBF88  LUI        R30, 49032
0x9D000068        0xAFC060C0  SW        R0, 24768(R30)
;01_blinkLED.c, 10 ::                 LATG = 0;
0x9D00006C        0x3C1EBF88  LUI        R30, 49032
0x9D000070        0xAFC061A0  SW        R0, 24992(R30)
;01_blinkLED.c, 11 ::                 LATD = 0;
0x9D000074        0x3C1EBF88  LUI        R30, 49032
0x9D000078        0xAFC060E0  SW        R0, 24800(R30)
;01_blinkLED.c, 13 ::                 while(1)
L_main0:
;01_blinkLED.c, 16 ::                 LATG = ~LATG;
0x9D00007C        0x3C1EBF88  LUI        R30, 49032
0x9D000080        0x8FC261A0  LW        R2, 24992(R30)
0x9D000084        0x00401027  NOR        R2, R2, R0
0x9D000088        0x3C1EBF88  LUI        R30, 49032
0x9D00008C        0xAFC261A0  SW        R2, 24992(R30)
;01_blinkLED.c, 17 ::                 LATD = ~LATD;
0x9D000090        0x3C1EBF88  LUI        R30, 49032
0x9D000094        0x8FC260E0  LW        R2, 24800(R30)
0x9D000098        0x00401027  NOR        R2, R2, R0
0x9D00009C        0x3C1EBF88  LUI        R30, 49032
0x9D0000A0        0xAFC260E0  SW        R2, 24800(R30)
;01_blinkLED.c, 19 ::                 Delay_ms(1000);
0x9D0000A4        0x3C180196  LUI        R24, 406
0x9D0000A8        0x3718E6AA  ORI        R24, R24, 59050
L_main2:
0x9D0000AC        0x2718FFFF  ADDIU        R24, R24, -1
0x9D0000B0        0x1700FFFE  BNE        R24, R0, L_main2
0x9D0000B4        0x70000000  NOP
;01_blinkLED.c, 20 ::                 }
0x9D0000B8        0x0B40001F  J        L_main0
0x9D0000BC        0x70000000  NOP
;01_blinkLED.c, 21 ::                 }
L_end_main:
L__main_end_loop:
0x9D0000C0        0x0B400030  J        L__main_end_loop
0x9D0000C4        0x70000000  NOP
; end of _main
___CC2DW:
;__Lib_System.c, 4 ::
0x9D000000        0x27BDFFFC  ADDIU        SP, SP, -4
;__Lib_System.c, 6 ::
L_loopDW:
;__Lib_System.c, 7 ::
0x9D000004        0x831E0000  LB        R30, 0(R24)
;__Lib_System.c, 8 ::
0x9D000008        0xA2FE0000  SB        R30, 0(R23)
;__Lib_System.c, 9 ::
0x9D00000C        0x26F70001  ADDIU        R23, R23, 1
;__Lib_System.c, 10 ::
0x9D000010        0x16F6FFFC  BNE        R23, R22, L_loopDW
;__Lib_System.c, 11 ::
0x9D000014        0x27180001  ADDIU        R24, R24, 1
;__Lib_System.c, 13 ::
L_end___CC2DW:
0x9D000018        0x03E00008  JR        RA
0x9D00001C        0x27BD0004  ADDIU        SP, SP, 4
; end of ___CC2DW
___BootStartUp:
;__Lib_System.c, 68 ::
0xBFC00000        0x27BDFFFC  ADDIU        SP, SP, -4
;__Lib_System.c, 72 ::
0xBFC00004        0x70000000  NOP
;__Lib_System.c, 73 ::
0xBFC00008        0x70000000  NOP
;__Lib_System.c, 74 ::
0xBFC0000C        0x70000000  NOP
;__Lib_System.c, 75 ::
0xBFC00010        0x70000000  NOP
;__Lib_System.c, 76 ::
0xBFC00014        0x70000000  NOP
;__Lib_System.c, 77 ::
0xBFC00018        0x70000000  NOP
;__Lib_System.c, 78 ::
0xBFC0001C        0x70000000  NOP
;__Lib_System.c, 79 ::
0xBFC00020        0x70000000  NOP
;__Lib_System.c, 80 ::
0xBFC00024        0x70000000  NOP
;__Lib_System.c, 81 ::
0xBFC00028        0x70000000  NOP
;__Lib_System.c, 82 ::
0xBFC0002C        0x70000000  NOP
;__Lib_System.c, 83 ::
0xBFC00030        0x70000000  NOP
;__Lib_System.c, 84 ::
0xBFC00034        0x70000000  NOP
;__Lib_System.c, 85 ::
0xBFC00038        0x70000000  NOP
;__Lib_System.c, 86 ::
0xBFC0003C        0x70000000  NOP
;__Lib_System.c, 87 ::
0xBFC00040        0x70000000  NOP
;__Lib_System.c, 88 ::
0xBFC00044        0x70000000  NOP
;__Lib_System.c, 89 ::
0xBFC00048        0x70000000  NOP
;__Lib_System.c, 90 ::
0xBFC0004C        0x70000000  NOP
;__Lib_System.c, 91 ::
0xBFC00050        0x70000000  NOP
;__Lib_System.c, 94 ::
0xBFC00054        0x3C1DA000  LUI        SP, 40960
0xBFC00058        0x37BD3FFC  ORI        SP, SP, 16380
;__Lib_System.c, 95 ::
0xBFC0005C        0x3C01A000  LUI        GP, 40960
0xBFC00060        0x34218000  ORI        GP, GP, 32768
;__Lib_System.c, 99 ::
0xBFC00064        0x401E6002  MFC0        R30, 12, 2
;__Lib_System.c, 100 ::
0xBFC00068        0x03C0E00A  MOVZ        R28, R30, R0
;__Lib_System.c, 101 ::
0xBFC0006C        0x7FDB1E80  EXT        R27, R30, 26, 4
;__Lib_System.c, 102 ::
0xBFC00070        0x7F7E4984  INS        R30, R27, 6, 4
;__Lib_System.c, 103 ::
0xBFC00074        0x409E6002  MTC0        R30, 12, 2
;__Lib_System.c, 104 ::
0xBFC00078        0x41C10800  WRPGPR        GP, GP
;__Lib_System.c, 105 ::
0xBFC0007C        0x409C6002  MTC0        R28, 12, 2
;__Lib_System.c, 111 ::
0xBFC00080        0x3C02A421  LUI        R2, 42017
0xBFC00084        0x34420583  ORI        R2, R2, 1411
0xBFC00088        0x0040F00A  MOVZ        R30, R2, R0
0xBFC0008C        0x409E8000  MTC0        R30, 16, 0
;__Lib_System.c, 114 ::
0xBFC00090        0x0000100A  MOVZ        R2, R0, R0
0xBFC00094        0x0040F00A  MOVZ        R30, R2, R0
0xBFC00098        0x409E4800  MTC0        R30, 9, 0
;__Lib_System.c, 117 ::
0xBFC0009C        0x3C02FFFF  LUI        R2, 65535
0xBFC000A0        0x3442FFFF  ORI        R2, R2, 65535
0xBFC000A4        0x0040F00A  MOVZ        R30, R2, R0
0xBFC000A8        0x409E5800  MTC0        R30, 11, 0
;__Lib_System.c, 119 ::
0xBFC000AC        0x3C029FC0  LUI        R2, 40896
0xBFC000B0        0x34421000  ORI        R2, R2, 4096
0xBFC000B4        0x0040F00A  MOVZ        R30, R2, R0
0xBFC000B8        0x409E7801  MTC0        R30, 15, 1
;__Lib_System.c, 121 ::
0xBFC000BC        0x34020020  ORI        R2, R0, 32
0xBFC000C0        0x0040F00A  MOVZ        R30, R2, R0
0xBFC000C4        0x409E6001  MTC0        R30, 12, 1
;__Lib_System.c, 123 ::
0xBFC000C8        0x3C020400  LUI        R2, 1024
0xBFC000CC        0x0040F00A  MOVZ        R30, R2, R0
0xBFC000D0        0x409E6002  MTC0        R30, 12, 2
;__Lib_System.c, 124 ::
0xBFC000D4        0x0000100A  MOVZ        R2, R0, R0
0xBFC000D8        0x0040F00A  MOVZ        R30, R2, R0
0xBFC000DC        0x409E6003  MTC0        R30, 12, 3
;__Lib_System.c, 129 ::
0xBFC000E0        0x3C020010  LUI        R2, 16
0xBFC000E4        0x0040F00A  MOVZ        R30, R2, R0
0xBFC000E8        0x409E6000  MTC0        R30, 12, 0
;__Lib_System.c, 132 ::
0xBFC000EC        0x34020032  ORI        R2, R0, 50
0xBFC000F0        0x3C1EBF88  LUI        R30, 49032
0xBFC000F4        0xAFC24000  SW        R2, 16384(R30)
;__Lib_System.c, 137 ::
0xBFC000F8        0x34021000  ORI        R2, R0, 4096
0xBFC000FC        0x3C1EBF88  LUI        R30, 49032
0xBFC00100        0xAFC21000  SW        R2, 4096(R30)
;__Lib_System.c, 143 ::
0xBFC00104        0x3C020080  LUI        R2, 128
0xBFC00108        0x0040F00A  MOVZ        R30, R2, R0
0xBFC0010C        0x409E6800  MTC0        R30, 13, 0
;__Lib_System.c, 149 ::
0xBFC00110        0x3C1E9D00  LUI        R30, hi_addr(_main+0)
;__Lib_System.c, 150 ::
0xBFC00114        0x37DE0050  ORI        R30, R30, lo_addr(_main+0)
;__Lib_System.c, 152 ::
0xBFC00118        0x03C00008  JR        R30
;__Lib_System.c, 153 ::
0xBFC0011C        0x70000000  NOP
;__Lib_System.c, 155 ::
L_end___BootStartUp:
0xBFC00120        0x03E00008  JR        RA
0xBFC00124        0x27BD0004  ADDIU        SP, SP, 4
; end of ___BootStartUp
___BootGenExcept:
;__Lib_System.c, 56 ::
0x9D000038        0x27BDFFFC  ADDIU        SP, SP, -4
;__Lib_System.c, 57 ::
L___BootGenExcept6:
;__Lib_System.c, 58 ::
0x9D00003C        0x0B40000F  J        L___BootGenExcept6
0x9D000040        0x70000000  NOP
;__Lib_System.c, 59 ::
L_end___BootGenExcept:
0x9D000044        0x27BD0004  ADDIU        SP, SP, 4
0x9D000048        0x42000018  ERET
0x9D00004C        0x70000000  NOP
; end of ___BootGenExcept
___GenExcept:
;__Lib_System.c, 61 ::
0x9D000020        0x27BDFFFC  ADDIU        SP, SP, -4
;__Lib_System.c, 62 ::
L___GenExcept8:
;__Lib_System.c, 63 ::
0x9D000024        0x0B400009  J        L___GenExcept8
0x9D000028        0x70000000  NOP
;__Lib_System.c, 64 ::
L_end___GenExcept:
0x9D00002C        0x27BD0004  ADDIU        SP, SP, 4
0x9D000030        0x42000018  ERET
0x9D000034        0x70000000  NOP
; end of ___GenExcept
Symbol List:
//** Routines locations **
//ADDRESS    SIZE    PROCEDURE
0x9D000000      [32]    ___CC2DW
0x9D000020      [24]    ___GenExcept
0x9D000038      [24]    ___BootGenExcept
0x9D000050     [120]    _main
0xBFC00000     [296]    ___BootStartUp
//** Variables locations **
//ADDRESS    SIZE    VARIABLE
Offline Howardlong
« Reply #15 on: July 24, 2016, 07:30:23 am »
Firstly, your program looks reasonable.
Secondly, trying to get Microchip's toolchain output to work with Mikroe's bootloader is likely to be a bit of work as you are already finding!
I don't have your board, but it would appear from the docs that it relies on Mikroe's toolchains and IDE to operate. And there the problem lies, that of vendor lock in, Mikroe's business model is to keep you coming back to them for hardware and compilers, they don't much want you going off to Microchip or anyone else.
It may well be that you're going to need to apply a linker file to your MPLAB X project to allow your code to co-exist with Mikroe, including entry point of course. Add to that any requirements in the future for interrupts and for IVT remapping, and how the bootloader deals with that, you could be in for quite a bit of detctive work. Getting a PIC32 linker file to work properly can be a significant piece of work in itself,
While I realise this isn't going to help you with your immediate problem, a similar option is the Microstick II which includes a proper programmer/debugger and is not dependent on any bootloader. If your requirement is for lots of pins and backwards compatibilty to a PIC16F877 pinout then your board may be OK but I'd see of you can hook up a PICkit3 to it and absolve yourself of the bootloader altogether.
  • Country: at
« Reply #16 on: July 24, 2016, 08:00:48 am »
Yes, it seems that this is their goal.
I had a look at the memory in comparison and I also think that this is just too much work to get it running.
This Microstick looks very interesting but I think it I need something more flexible.
The reason why I bought the Mini-32 was that it is perfectly suitable for plugging it into a breadboard, it was cheap and I don't need a programmer. And Microchip was my preferred supplier because they offer an IDE for OS X which is also the main reason why I don't want to use the IDE from MikroElektronika. Maybe I will switch to STM32 because their evaluation boards are really cheap and have the programmer/debugger included...
Offline Howardlong
« Reply #17 on: July 24, 2016, 09:11:59 am »
What is it that the Microstick II doesn't do that you would need the mini-32 for?
The Microstick II:
O on board programmer and debugger
O selection of four devices included, including PIC32MX250F128B
O works with MPLAB X in OS X
O plugs directly into breadboard
Mini-32 is $28, Microstick II is $35, so yes, a $7 premium.
  • Country: at
« Reply #18 on: July 24, 2016, 11:07:22 am »
I know, it's quite the microstick same or even better but unfortunately I didn't saw it before I bought the Mini-32.
Nevertheless I am still struggling about starting to develop with ST Micro or microchip... The big pro for ST is that they have a programmer included with their DEV boards which can also be used for programming chips which are on a designed pcb...
I assume that you did the most on pics?
Offline dannyf
« Reply #19 on: July 24, 2016, 11:26:27 am »
That's the code I gave you: one without config bits and another with.
So it is interesting that you reported that the MikroC code worked and the two .hex files I provided didn't.
The ST programmers go for peanuts.
Offline Howardlong
« Reply #20 on: July 24, 2016, 12:00:42 pm »
Yes, at this level, mostly PICs but also a fair bit on NXP and TI ARM Cortex M0 thru M4F, and occasionally AVR UC3.
When you've invested a lot of time in particular ecosystems you tend to keep with them, not least because you risk being a jack of all trades and master of none.
I have nothing against ST, and have collected several dev boards over the years, I've just never had a requirement to use their devices over something else, or at least the need to learn yet another ecosystem, as it could be done with something I already knew.
  • Country: at
« Reply #21 on: July 24, 2016, 12:11:40 pm »
Yeah that's true... Really strange...
So far I have done some simple projects with AVRs but I wanted to switch to more powerful devices for driving displays and so on. Both solutions (STM32 and PIC32) are suitable... [emoji4]
Offline hugo
« Reply #22 on: July 25, 2016, 08:56:41 pm »
Forget about mikroe bootloader, buy a PICKIT 3 and use it with MPLABX IDE .
