Im working on a simple LiPol projects and im using LTC2942 Fuel gauge ic. I want to read data from that ic using zero gecko microcontroller, but the problem is that its default library emlib doesnt support read command without repeated start which my fuel gauge requires (its using SMBus). Does anyone know how to fixed it?
I tried simple write to register and than read but because of the stop condition after each command this approach doesnt work.
LTC2942 datasheet (
http://cds.linear.com/docs/en/datasheet/2942fa.pdf)
Aplication note on using SMBus as an I2C device (
http://www.ti.com/lit/an/sloa132/sloa132.pdf)
