Can you run through really quick how you came up with your bandwidth estimate? I'm def getting a figure appreciably lower than ~1485 Mbps:
Assuming 60 fps @ ~5% reduced blanking, I'm getting:
(1920 x 1080 x 60 x 10 x 1.05) / 220 ~= 1246 Mbps
I would imagine handling 1080p/24 should be without issue.
It wasn't so much about generating 1080p, but accepting 1080p from a standard source (so I can play around with the video).
SMTPE 1080p@60 (which is what I am expecting a source to supply - e.g. a generic media player) is 2200 counts per line, 1125 lines per frame, 60 frames per second. As TMDS uses an 8b/10b coding scheme, it needs 2200×1125×60×10 = 1,485 Mb/s
Or perhaps simpler, the standard 1080p pixel clock is 148.5 MHz so the per channel bit rate is 1,485 Mb/s, on each of the three channels (for 24 bits per pixel colour depth)
