Author Topic: 16f1825 MCC i2c with PCA985  (Read 189 times)
Offline JonPyro
« on: April 25, 2018, 11:49:23 pm »
Hi All,
I am a little lost as I have never really implemented I2C before on a PIC with MCC.
I am trying to talk to the PCA9685 (datasheet : https://www.nxp.com/docs/en/data-sheet/PCA9685.pdf) on a servo driver board bought off ebay using a 16f1825 and using MCC to generate the I2C functions. However, I am at a loss to work out how to use the functions MCC has generated.
Here is my thinking, first define the registers from the datasheet I want to access and the new pre-scaler (I want 50hz pwm for servos and not the default 200hz):
#define PCA9685_ADDRESS        0x40
#define PCA9685_MODE1          0x00
#define PCA9685_PRESCALE       0xFE
#define PCA9685_MODE1_SLEEP    0x10
#define PCA8695_MODE1_RESTART  0x80
int PreScaleValue = 0x79;
Now in the main program I should be using:
void I2C_MasterWrite(
            uint8_t *pdata,
            uint8_t length,
            uint16_t address,
            I2C_MESSAGE_STATUS *pstatus);
So would you write that something along the lines of this if I wanted to sleep the chip and change the pre-scale:
    writeBuffer[0] = PCA9685_MODE1_SLEEP;
    writeBuffer[1] = PCA9685_PRESCALE;
    writeBuffer[2] = PreScaleValue;
    I2C_MasterWrite(writeBuffer,1, PCA9685_ADDRESS, &status);
Any help would be appreciated ;)
