Hello dears
This is the entire code from the CCS C compiler "2464.C" header, and I am struggling with something which may be obvious, but it ain't to me:
//// Library for a 24LC64 serial EEPROM ////
//// init_ext_eeprom(); Call before the other functions are used ////
//// write_ext_eeprom(a, d); Write the byte d to the address a ////
//// d = read_ext_eeprom(a); Read the byte d from the address a ////
//// The main program may define eeprom_sda ////
//// and eeprom_scl to override the defaults below. ////
//// (C) Copyright 1996,2003 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
#ifndef EEPROM_SDA
#define EEPROM_SDA PIN_C5
#define EEPROM_SCL PIN_C4
#endif
#use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL)
#define EEPROM_ADDRESS long int
#define EEPROM_SIZE 8192
void init_ext_eeprom()
output_FLOAT(EEPROM_SCL);
output_FLOAT(EEPROM_SDA);
void write_ext_eeprom(long int address, BYTE data)
short int status;
i2c_start();
i2c_write(0xa0);
i2c_write((address>>8)&0x1f); <<---------------------- What is this for?
i2c_write(address);
i2c_write(data);
i2c_stop();
i2c_start();
status=i2c_write(0xa0);
while(status==1)
i2c_start();
i2c_stop();
BYTE read_ext_eeprom(long int address) {
BYTE data;
i2c_start();
i2c_write(0xa0);
i2c_write(address);
i2c_start();
i2c_write(0xa1);
data=i2c_read(0);
i2c_stop();
return(data);
Why does the code shift that byte to the right, by 8 places? That just means the byte ends up exactly the same as it was BEFORE it was shifted. I am gradually learning I2C, and I must confess that this has stumped me. Could someone explain for me, please? Thank you
