Author Topic: 6502 KIMATH, should I try and port it to Z80 or AVR mega?  (Read 16879 times)
Offline commieTopic starter
Re: 6502 KIMATH, should I try and port it to Z80 or AVR mega?
« Reply #25 on: October 18, 2015, 10:02:06 pm »
http://www.micromegacorp.com/ make this add on fpu for avrs and things. its interesting, uses i2c/spi to talk etc. 5v tolerant. may or may not be useful info.
And the venerable: http://www.awce.com/pak1.htm -- surprising what these have found their way in. If you prefer an "ASCII" calculator try http://awce.com/pak12.htm
Here we go again, you cannot use 32 or 64 bit IEEE 754 floating point for accurate calculations, the reason for this is that there is a error prone conversion process going from ascii to fp and from fp  back to ascii. The solution to this problem is to use BCD notation which requires no error going in/out of the processor.
« Reply #26 on: October 18, 2015, 10:12:39 pm »
I don't understand this thread. Surely whatever is coded into this 6502 routine is derived from an algorithm that you can easily translate to whatever CPU you choose?
You must be joking :-DD, you think software comes equipped with a flow chart?
Seriously, why are you fixated on a math function from the 70's in 6502 to port to AVR when there are so many others you could use instead?
Because up to the present, there is nothing to replace it.Why did TI use an old '70's z80 for their range of graphing calculators?
Offline IanB
« Reply #27 on: October 18, 2015, 10:50:29 pm »
But I'm glad someone recognises how difficult the task is. I just want to point out something else as well, my AVR compiler supports IEEE 754 64-bit floats, but I can't use it because of the errors induced into the argument going from in to out and out to in and that's why calculators only use bcd.
This is not, in fact, true. You are creating difficulties for yourself by imagining a problem that is not there.
When used correctly, floating point arithmetic in any base is just as susceptible to precision errors as in any other base (whether decimal or binary). Where BCD is chosen (for example for financial calculations) it is fixed point, not floating point. Fixed point leads to a different set of issues, which in same applications may be easier to manage.
There is a reason scientific computing is done with binary floating point arithmetic on every computer in the world. Pocket calculators were designed differently not for reasons of precision or accuracy, but for convenience of design with a small chip count and low power consumption. Double precision 64-bit IEEE 754 is far more accurate than any pocket calculator I have compared it with.
« Last Edit: October 18, 2015, 11:33:47 pm by IanB »
Offline Macbeth
« Reply #28 on: October 18, 2015, 10:55:51 pm »
commie, no flow chart - you just need to use something called a disassembler. Make your own from that.
Besides the only time I've ever encountered such (non floating) decimal point is in crappy ancient mainframe COBOL stuff that was riddled with Y2K bugs.
The principle is very simple - why not code your own from scratch?
Online Ian.M
« Reply #29 on: October 18, 2015, 11:14:43 pm »
Writing high precision floating point applications for a legacy 8 bit CPU in assembler is pure masochism.  You either have or can obtain C compilers for all your potential targets except the 6502, and already have been pointed at an ANSI C IEE 754 decimal64/decimal128 compatible float library.
Offline richardman
« Reply #30 on: October 18, 2015, 11:35:37 pm »
I am sure a 84MHz STM32F411 at $7 a chip, will run a 6502 emulator faster than a 1MHz 6502 :-), let alone with all the other alternative ways that people have suggested already.
// richard http://imagecraft.com/
JumpStart C++ for Cortex (compiler/IDE/debugger): the fastest easiest way to get productive on Cortex-M.
Smart.IO: phone App for embedded systems with no app or wireless coding
Offline westfw
« Reply #31 on: October 19, 2015, 01:56:48 am »
the AVR has no BCD support instructions in it
they were one of the first things to disappear in "RISC" instruction sets.
As Ian said, this is crap.   There is a deterministic and predictable imprecision in conversion of ascii decimal floating point numbers to binary representations.  If your program is constantly converting back and forth, it might need to pay attention to this.  (but, most programs don't.) (and... any floating point representation introduces errors that you need to pay attention to in high-precision calculations, just because there are always some values that can't be represented exactly.  They used to teach this, back when floats were only 32 to 36 bits.  It seems largely ignored now that they're 64 to 80 bits or more.)
Do you need actual floating point?   As several people have pointed out, there are a bunch of standard multi-precision libraries written in nice level languages with lots of documentation.    Some have been ported to small microcontrollers - for example the gnu "bc" library has been ported to Arduino: http://www.gammon.com.au/forum/?id=11519   Several languages support arbitrary precision math in addition to standard floating point formats...
Offline daybyter
Offline ale500
« Reply #33 on: October 19, 2015, 05:02:56 am »
The reason: speed. No other reason. If decimal arithmetic were as fast as binary, binary would not be used. And anyways at least for chemistry, the constants used to describe the atoms are 7, 8, 9 digits accurate...
Offline Bruce Abbott
    • Bruce Abbott's R/C Models and Electronics
« Reply #34 on: October 19, 2015, 05:22:40 pm »
note I'm not trying to convert from binary to bcd or bcd to binary, instead I want to do bcd arithmetic.
;**** A P P L I C A T I O N   N O T E   A V R 2 0 4 ************************
;* Title:      BCD Arithmetics
;* Version:      1.1
;* Last updated:   97.07.04
;* Target:      AT90Sxxxx (All AVR Devices)
;* Support E-mail:   avr@atmel.com
;* DESCRIPTION
;* This Application Note lists subroutines for the following Binary Coded
;* Decimal arithmetic applications:
;* Binary 16 to BCD Conversion (special considerations for AT90Sxx0x)
;* Binary 8 to BCD Conversion
;* BCD to Binary 16 Conversion
;* BCD to Binary 8 Conversion
;* 2-Digit BCD Addition
;* 2-Digit BCD Subtraction
« Reply #35 on: October 19, 2015, 07:35:06 pm »
;* Version:      1.1
;* DESCRIPTION
Bruce, thank you for trying, I have seen this document and I can already do 2 digit bcd add/subtract. What I am looking for is 'at least' 16 digits bcd multiply and divide with auto exponents.
« Reply #36 on: October 19, 2015, 07:58:23 pm »
Why is it crap?, Using IEEE754 32 bit floats requires two associated i/o routines for use which convert an ascii string(number) into 32 bit floating point format, this input routine introduces small errors.Some numbers have an exact fit but many don't and those that don't fit produce a small error. If you now send the same 32 bit float to the screen there is likely to be yet another small error introduced because of the conversion process of the output routine.
IEEE754 fp's are extremely byte efficient, at the expense of accuracy because IEEE754 require elaborate i/o routines to function correctly.
BCD floating point, on the other hand, don't need an i/o routine, they are completely transparent to binary/hex and decimal. Do you think the smart guys would include bcd floating point arithmetic in our compilers? and if they did, risk destroying the international calculator industry at large?
IEEE 754 is of course okay for use in the process/instrumentation industry because we only display the result to one or two fractional decimal digits where errors of IEEE754 don't show or are too small to be any significance.
« Last Edit: October 19, 2015, 08:17:10 pm by commie »
« Reply #37 on: October 20, 2015, 08:19:57 am »
The 6502 only two has instructions that use BCD - ADC and SBC. If you can emulate these on the AVR then porting the the rest of the code should be easy. AVR204 show you how to do it.
Offline Kalvin
  • Embedded SW/HW.
« Reply #38 on: October 20, 2015, 11:01:32 am »
You can even use one byte for each digit, so you don't have to use the BCD-related instructions and you don't have to unpack and pack the digits when performing multiply and division, for instance. The exponent +/- 127 can be packed into one byte, it can be used as an ordinary signed integer, and it will not suffer from the rounding errors. One-byte-per-digit "wastes" some memory, but otherwise it will make your life easier. And, if the RAM space is really of concern, you can always unpack and pack the numbers before and after you operate on the numbers.
« Last Edit: October 20, 2015, 12:39:43 pm by Kalvin »
Offline westfw
« Reply #39 on: October 20, 2015, 03:28:19 pm »
Ooohh.  There is now "Dense Packed Decimal."  3 digits in 10bits.  (though apparently you unpack it to use it...)
Offline Kalvin
  • Embedded SW/HW.
« Reply #40 on: October 20, 2015, 03:37:59 pm »
Better yet, you can pack four digits in the 14bits! ;)
« Reply #41 on: October 20, 2015, 06:50:21 pm »
The KImath routines use packed and unpacked bcd extensively,  their argument for doing this, is it makes bcd multiplication/division execution very quick and one website I have came across, goes so far as to say unpacked bcd is the only way to bcd multiplication/division.KImath was introduced for the Mos Technology 6502 KIM 1 sometime during 1976. I have two books, one for the 6502 the other for the Z80, these books were published during 1984, in both of them I have found a multi digit bcd multiplication/division/subtraction and addition routines.
I've keyed in the multiplication routine and sure enough it works, to increase the number of digits  is trivial. Nowhere in the text is there any hint or reference to packed/unpacked bcd?. The routine is about 200 bytes long and is complicated, I get lost trying to follow it but there you go.
The problem now is, how do I attach an exponent to a multi byte bcd number? The only viable way I can think of, is repeated division by 10 and counting the divisions until the number drops below 10 in value, the division count is then your exponent value.
If anyones interested, "Z80 ASSEMBLY LANGUAGE SUBROUTINES", by Lance A. Leventhal and Winthrop Saville 1983
Offline Rasz
    • My random blog.
« Reply #42 on: October 21, 2015, 07:07:35 am »
 :palm:
Offline westfw
« Reply #43 on: October 21, 2015, 09:30:18 am »
You still haven't said what's wrong with the existing multi-precision libraries.   The BC library that's been ported to Arduino is one digit per byte, so it shouldn't have any problem addressing your concerns about conversion accuracy...
« Reply #44 on: October 21, 2015, 05:45:23 pm »
Do you mean how to convert a BCD integer or fixed point number (eg. 12345.6789) to floating point (eg. 1.23456789 e+4)? Just skip any leading zeros and count the number of digits before/after the decimal point.
« Reply #45 on: October 21, 2015, 06:24:53 pm »
Hi Bruce,
Yep, that's what I thought originally, but supposing you multiply two 12 digit fixed point numbers together and suppose the answer comes out with say arbitrary as 1234000056789, i.e., note the zero's are embedded in the result, so my zero detector comes along and detects a pair of zeros and my software thinks it has come to the end of the result when  in fact it all it has done is detected zero in the middle of the result, right?  :-//
« Last Edit: October 21, 2015, 06:46:11 pm by commie »
Offline ale500
« Reply #46 on: October 21, 2015, 06:38:04 pm »
You don't stop at zeros.. you have to count them all. Because each digit on the right of the first non-zero on the left if not significant because of limited number of digits give you the exponent when on the left of the decimal point.
I follow this from the start and I think you may be seeing this thing all wrong. Just write on paper how the number should look like and how you are going to store it. You may get a better picture. Your "floating point" number is a structure with three fields, the exponent is one of them, you store it either at the beginning or at the end it doesn't matter as long as you always treat the structure the same way...
« Reply #47 on: October 21, 2015, 07:05:13 pm »
Your last post has given me new inspiration, I was counting from the wrong direction/end, thanks for that Bruce and ALE500. :D
I've got some work to do.
« Last Edit: October 21, 2015, 07:07:36 pm by commie »
Offline exmadscientist
  • Technically A Professional
« Reply #48 on: October 22, 2015, 04:37:33 am »
Bruce Dawson has what is, in my mind, the definitive response to this... concern....
His entire series of blog posts on IEEE-754 floating point is highly recommended reading for anyone who wants to really understand -- or thinks they already understand -- the guts and twisted dark corners of IEEE-754.
Offline ale500
« Reply #49 on: October 22, 2015, 04:51:28 am »
Here is some working code in C for BCD fp mul:
I compiled it and tested in avr, arm and pic32 (mips). The given time is for mips. It encodes one BCD (base-10) per byte. I went for base 100 because you get the same speed for two times the number of digits.
#ifdef SMALL
    #define BCD_MAXDIGITS 8
    #define BCD_MAXWIDTH  13
    #define BCD_MAX_EXP 99
    #define BCD_MIN_EXP -99
    typedef int8_t exp_t;
#else
    #define BCD_MAXDIGITS 20 // we should safely get 16 decimal places
    #define BCD_MAXWIDTH  24
    #define BCD_MAX_EXP 999
    #define BCD_MIN_EXP -999
    typedef int16_t exp_t;
#endif
#define BCD_LASTDIGIT (BCD_MAXDIGITS-1)
typedef struct {
    uint8_t sign;
    exp_t dexp;
    uint8_t frac[BCD_MAXDIGITS];
} T_SBCDREAL;
_CNT uint8_t mullow[][16] = { { 0 },
                            { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9 },
                            { 0, 2, 4, 6, 8, 0, 2, 4, 6, 8 },
                            { 0, 3, 6, 9, 2, 5, 8, 1, 4, 7 },
                            { 0, 4, 8, 2, 6, 0, 4, 8, 2, 6 },
                            { 0, 5, 0, 5, 0, 5, 0, 5, 0, 5 },
                            { 0, 6, 2, 8, 4, 0, 6, 2, 8, 4 },
                            { 0, 7, 4, 1, 8, 5, 2, 9, 6, 3 },
                            { 0, 8, 6, 4, 2, 0, 8, 6, 4, 2 },
                            { 0, 9, 8, 7, 6, 5, 4, 3, 2, 1 } };
_CNT uint8_t mulhigh[][16] = { { 0 },
                            { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
                            { 0, 0, 0, 0, 0, 1, 1, 1, 1, 1 },
                            { 0, 0, 0, 0, 1, 1, 1, 2, 2, 2 },
                            { 0, 0, 0, 1, 1, 2, 2, 2, 3, 3 },
                            { 0, 0, 1, 1, 2, 2, 3, 3, 4, 4 },
                            { 0, 0, 1, 1, 2, 3, 3, 4, 4, 5 },
                            { 0, 0, 1, 2, 2, 3, 4, 4, 5, 6 },
                            { 0, 0, 1, 2, 3, 4, 4, 5, 6, 7 },
                            { 0, 0, 1, 2, 3, 4, 5, 6, 7, 8 } };
 * Multiplies 2 BCD numbers
 * it can use the same number as argument and result
 * 99.99999999*99.99999999 takes 1833*2 with -O3
void t_bcd_mul(T_SBCDREAL *r, T_SBCDREAL *a, T_SBCDREAL *b)
    int8_t i, j, k, y, c;
    uint8_t frac[BCD_MAXDIGITS*2];
    uint8_t *xl, *xh;
    r->dexp = a->dexp + b->dexp;
    r->sign = a->sign ^ b->sign;
    for (i = 0; i < BCD_MAXDIGITS+BCD_MAXDIGITS; i++) frac[i] = 0;
    for (i = BCD_MAXDIGITS-1; i >= 0; i--)
        j = b->frac[i];
        if (j) {
            xl = (uint8_t *)&mullow[j][0];
            xh = (uint8_t *)&mulhigh[j][0];
            k = BCD_MAXDIGITS + i;
            c = 0;
            for (j = BCD_MAXDIGITS-1; j >= 0; j--, k--) {
                y = *(xl+a->frac[j]) + c + frac[k];
                c = *(xh+a->frac[j]);
                if (y >= 10)
                    c++;
                    y -= 10;
                frac[k] = y;
            frac[k] = c; // last carry
    if (c) {  // MSD is the carry
        for (i = 0; i < BCD_MAXDIGITS; i++)
            r->frac[i] = frac[i];
        r->dexp++;
        r->frac[0] = c;
    else
            r->frac[i] = frac[i+1];
« Last Edit: October 22, 2015, 04:54:37 am by ale500 »
