Author Topic: ad9850  (Read 5398 times)
Offline sfiberTopic starter
  • Country: tr
ad9850
« on: August 10, 2014, 08:55:13 am »
hi friends I use stm32f4 and I try this code with ad9850 module.
but there is a problem I think.Because when I debug data_to_load and frequency_to_load parameters never take a value.
can you check this and if you have a sample code can you share with me
#include "stm32f4_discovery.h"
//d8 w_clk
//d9 frequency update
//d10 data
//d11 reset
GPIO_InitTypeDef GPIO_InitStructure;
int i,b;
void delay(uint32_t count);
void Load_Frequency(long long frequency_to_load);
void load_bytes(uint16_t data_to_load);
void PIN_Initing(void)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD,ENABLE);
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_15;
GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_NOPULL;
GPIO_InitStructure.GPIO_OType=GPIO_OType_PP;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_100MHz;
GPIO_Init(GPIOD,&GPIO_InitStructure);
for(i=0;i<8;i++,data_to_load>>=1)
GPIO_WriteBit(GPIOD,GPIO_Pin_10,(data_to_load & 0x01));
GPIO_SetBits(GPIOD,GPIO_Pin_8);
delay(0x00000010);
GPIO_ResetBits(GPIOD,GPIO_Pin_8);
long long freq=frequency_to_load*4294967295/125000000;
for(b=0;b<4;b++,freq>>=8)
load_bytes(freq & 0xFF);
delay(0x0000050);
load_bytes(0x0000);
GPIO_SetBits(GPIOD,GPIO_Pin_9);
while(count--)
int main(void)
PIN_Initing();
GPIO_SetBits(GPIOD,GPIO_Pin_15);
GPIO_SetBits(GPIOD,GPIO_Pin_11);
delay(0x0000F00);
Load_Frequency(10.e6);
  while(1)
Offline dannyf
Re: ad9850
« Reply #1 on: August 10, 2014, 10:28:30 am »
Why do you think they never take a value?
Offline bwat
    • My website
Re: ad9850
« Reply #2 on: August 10, 2014, 11:15:54 am »
Efendim, 10.e6 bir "float" ama bir "long long" istiyorsunuz, degil mi?
« Last Edit: August 10, 2014, 11:21:42 am by bwat »
"Who said that you should improve programming skills only at the workplace? Is the workplace even suitable for cultural improvement of any kind?" - Christophe Thibaut
"People who are really serious about software should make their own hardware." - Alan Kay
  • Country: tr
Re: ad9850
« Reply #3 on: August 10, 2014, 11:35:01 am »
I tried wtih double but nothing changed
Offline bwat
    • My website
Re: ad9850
« Reply #4 on: August 10, 2014, 11:49:56 am »
Why would you try with a double? Why not use a long long just like the function is specified to take as an argument?
  • Country: tr
Re: ad9850
« Reply #5 on: August 10, 2014, 12:08:27 pm »
what do you offer me to use
Offline bwat
    • My website
Re: ad9850
« Reply #6 on: August 10, 2014, 12:18:15 pm »
A long long perhaps? Basically, any integer type with at least 25 bits of precision will do since:
| ?- X is 1+ceiling(ln(10.0e6)/ln(2)).
X = 25 ?
Edit: My original formula was off by one!!! Fixed.
« Last Edit: August 10, 2014, 12:28:16 pm by bwat »
  • Country: tr
Re: ad9850
« Reply #7 on: August 10, 2014, 12:34:41 pm »
X = 25 ?
do you have a source code to use
Offline bwat
    • My website
Re: ad9850
« Reply #8 on: August 10, 2014, 12:48:53 pm »
1) You've misunderstood what I'm saying. Just use 10000000 instead of 10.0e6.
2) I should have used floor and not ceiling. I managed to mess up that simple formula twice!
Offline dannyf
Re: ad9850
« Reply #9 on: August 10, 2014, 02:02:31 pm »
The compiler, assuming that it is reasonably competent, would have done that conversion.
So it is not the problem - well, it shouldn't be the problem.
The OP never established why s/he thought the variables were not taking the values s/he expected them to.
  • Country: tr
Re: ad9850
« Reply #10 on: August 10, 2014, 06:32:00 pm »
yes completely true.variables dont take value.when I added them to watch window I can only see "not in scope".I never met problem like this.
Offline dannyf
Re: ad9850
« Reply #11 on: August 10, 2014, 06:51:31 pm »
We cannot help you if you refuse to help us help you.
Offline bwat
    • My website
Re: ad9850
« Reply #12 on: August 11, 2014, 09:41:53 am »
I agree it's probably not the source of his problem. I pointed it out as the conversion from a float to an int can be a source of undefined behaviour according to K&R 2nd edition. It was something he needed to sort out.
Offline abyrvalg
Re: ad9850
« Reply #13 on: August 13, 2014, 06:08:12 am »
Looks like you are trying to watch local variables outside of functions they belong to. Set a breakpoint INSIDE the Load_frequency() function - there you should see the frequency_to_load var w/o any problems. Same for data_to_load - it does exist only inside the load_data() function.
Note: you may need a second delay - after gpio_resetbits in load_data().
