Build instructionsTo build the compiler unfortunately you need an ada/c/c++ compiler already available, to produce an ada/c/c++ compiler.If you don't have an ada compiler available you must set the bootstrap use flags. In this case the compiler used will be gnat-gpl-2014-x86_64-linux-bin.tar.gz from libre.adacore.com.
Ada on SGI/IRIXThe Silicon Graphics AXM (Ada X/Motif) Ada Development System provides an Ada development environment for Silicon Graphics platforms. It consists ofAda compiler (ANSI/MIL-STD-1815A)X11 and OSF/MotifBindings to the IRIS Graphics LibraryNon-intrusive, symbolic debuggerMP/Ada 6.2 is a multiprocessor Ada development system. It's built using the POSIX-compliant threads model for Ada tasking. If your application runs on a multiprocessor platform, MP/Ada6.2 allows Ada tasks in this application to run concurrently.
so, I am looking at GNAT's recipe again QuoteBuild instructionsTo build the compiler unfortunately you need an ada/c/c++ compiler already available, to produce an ada/c/c++ compiler.If you don't have an ada compiler available you must set the bootstrap use flags. In this case the compiler used will be gnat-gpl-2014-x86_64-linux-bin.tar.gz from libre.adacore.com.and again it's a face palm There is NO boot-strapper for IBM-POWER, HPPA, MIPSBE ... you are doomedDoes anyone happen to know of something alternative? (opensource or commercial)and in this case, do you know if it's requested a license? yup
You cannot cros-compile from your existing x86 box?
VHDL is basically Ada
write your own Ada compiler
