Author Topic: Altera MAX 10 external memory?  (Read 10184 times)
Offline deephavenTopic starter
  • Civilization is just one big bootstrap
    • Deephaven Ltd
« on: December 27, 2014, 04:12:24 pm »
I was contemplating using a MAX 10 but I need some external DDR memory for it. Looking at the literature, Altera recommends using their "UniPHY IP core" and just wanted to know how much this costs? I can't seem to find costings on their website, but maybe I didn't look hard enough.
Otherwise, are there any DDR memory interface examples around?
Offline Marco
Re: Altera MAX 10 external memory?
« Reply #1 on: December 27, 2014, 09:15:06 pm »
No idea what their core costs but Xilinx has an appnote on using DDR with their CPLD (pretty basic, should be mostly portable) and Ray Bittner from Microsoft has an open source DDR2 controller.
« Last Edit: December 27, 2014, 09:16:37 pm by Marco »
    • Deephaven Ltd
« Reply #2 on: December 28, 2014, 04:16:23 pm »
Marco, thanks for the useful links.
Offline Scrts
  • Country: lt
« Reply #3 on: January 01, 2015, 07:58:05 pm »
Memory controllers from Altera are free of charge. Check the UniPHY core documentation of MAX10 family for supported memory devices.
    • Deephaven Ltd
« Reply #4 on: January 01, 2015, 08:08:23 pm »
I had a bit more of a look around Altera since my posting. I believe the UniPHY core core is free if I have a subscription edition of Quartus. I don't have a subscription right now, but I can still try it but it has to be connected to the programming adapter or there is a time limit on the run time. This should be fine as the subscription isn't too bad if I do decide to go with it after trying it out.
Offline miguelvp
« Reply #5 on: January 02, 2015, 03:58:02 am »
Check the BeScope code
http://www.arrownac.com/solutions/bescope/
Under Getting Started on the "Download Software (BeScope only)" link
The software is missing some important files that can be found here:
http://forums.parallax.com/showthread.php/157115-BeScopeBundle-System-Files
But that's only if you want to use it but for the memory access it's there.
Granted this is fro the BeMicro CV but they list the BeScope for their BeMicro Max 10
http://www.arrow.com/bemicro/
I have both but only than just compiling and testing the BeMicro CV with the BeScope (I got the bundle for $50 but they no longer have that bundle) I didn't analyze the code in detail yet, but it seems they access the memory directly without a NIOS II soft core so it's straight via the avalon interface
More info about the BeMicro Max 10 here including schematics:
http://www.alterawiki.com/wiki/BeMicro_MAX_10
If I find time to play with using the BeScope using the Max10 instead of the CycloneV I'll post it in here but might not be for quite a while.
Edit: upon closer inspection it has SDRAM not DDR at all, sorry but I'll leave the links in case SDRAM fits your needs.
« Last Edit: January 02, 2015, 04:17:28 am by miguelvp »
    • Deephaven Ltd
« Reply #6 on: January 02, 2015, 09:33:19 am »
Thanks for all the useful links. My existing design uses a Cyclone 2 with a 9 Mbit SDRAM. I rolled my own RAM controller for that one. I now need 32 Mbits and, although you can get SDRAM in that size, it is prohibitively expensive. In comparison, DDR RAM is peanuts, but it needs more brains to make it work. I also notice that Altera are only listing their 8K LE MAX 10 devices in their shop, so it might not be big enough for me, I need around 30K. This means I might have to go for a Cyclone 4 or 5 instead.
Offline mirecta
  • Country: sk
« Reply #7 on: October 11, 2016, 08:23:26 pm »
hi i have a question is here any progress with Bescope and BeMicroMax10 ? thanx for answer
Offline kilohercas
  • Engineer
« Reply #8 on: February 09, 2017, 02:26:12 pm »
This is related question:
If i want to connect 32b SDRAM ( not some DDR, but 3.3V CMOS level 32MB) can i do it, or i must use DQ pins for data ?
Because 484pin MAX10 50k only has 24b of DQ lines, but this is low speed device, it should connect to any pin expect for Vref pin of that bank, 100MHz is nothing for this altera... Even STM32F429 can connect to this memory, with no problems.
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #9 on: February 09, 2017, 03:24:46 pm »
You can connect SDRAM to pretty much every pin, AFAIK. You may want to check for dedicated clock pins, though.
Offline suicidaleggroll
« Reply #10 on: February 09, 2017, 04:29:45 pm »
You can connect SDRAM anywhere if the speed is low enough (say 50-100 MHz), for high speeds you may need to start paying attention to using dedicated clock pins.
I've used hamster's SDRAM controller in the past with good success.  It took a little bit of tweaking to get it running correctly for me, but not a lot.
http://hamsterworks.co.nz/mediawiki/index.php/Simple_SDRAM_Controller
Offline John_ITIC
  • ITIC Protocol Analyzers
    • International Test Instruments Corporation
« Reply #11 on: February 10, 2017, 03:35:34 am »
I believe only if you are using the subscription version of Quartus II (or whatever they call it these days)? Some $2,000 USD I believe (yearly)?
Pocket-Sized USB 2.0 LS/FS/HS Protocol Analyzer Model 1480A with OTG decoding.
Pocket-sized PCI Express 1.1 Protocol Analyzer Model 2500A. 2.5 Gbps with x1, x2 and x4 lane widths.
https://www.internationaltestinstruments.com
Offline amb
« Reply #12 on: February 11, 2017, 11:28:29 am »
@deephaven I've designed DDR2 and DDR3 interfaces with the Cyclone V, you should have a fairly easy ride if you go that way.
@kilohercas talking to SDRAM should be easy, but pay attention to clock timing; you may need to run different length traces from your clock source to the FPGA and the SDRAM to meet setup and hold, or (if it's possible) play with the FPGA clock phase internally to achieve the same result (this might include generating the SDRAM clock internally). Also: remember to analyse Simultaneous Switching Noise (SSN) - see Altera's "MAX 10 FPGA Signal Integrity Design Guidelines". Filling up a bank with data I/Os has caused me problems with this, one time I had to disperse them so that no bank had more than 50% output pins. Given the relatively low speed of SDRAM, another option might be to stagger the switching timing of your data I/Os by a few hundreds of ps or a few ns. A bit fiddly but may save the day if you're short of pins.
Offline Scrts
  • Country: lt
« Reply #13 on: February 11, 2017, 07:33:06 pm »
I've used 5 SDRAM devices with 5 separate memory controllers on EP3C55. One SDRAM for Nios II/f and another four for 7 compressed video data streams over custom made DMA.
MAX10 is faster generation than Cyclone III, so you can use every IO to interface SDRAM even at 100MHz.
However, pay very careful attention to SDRAM examples from, for example, old development kits. You will see that the PLL setup has two output clocks: one for SDRAM controller internally and another for SDRAM device itself. It will have about -3ns clock phase.
I gave you a hint and you can try to understand why ;)
In general, you should also use some primitives for clock output and understand how to write constraints file initially, then follow TimeQuest report.
Offline ale500
« Reply #14 on: February 12, 2017, 07:23:45 am »
@Scrts:
regarding your recommendation of a phase shift of -3 ns for the sdram clock, I was wondering if one could achieve the same results using the falling edge to output address and commands to the SDRAM and the rising edge, default on SDRAMs, for it to acquire and output data.
Let me ask you a related question:
Or is such a scheme to be avoided due to "don't mix", only use rising edge even in different domains ?.
Or is the answer you have 7 ns to process and output the data instead of 5 ns ?
Offline Scrts
  • Country: lt
« Reply #15 on: February 12, 2017, 03:23:10 pm »
@Scrts:
It depends on clock frequency you use. This is why the difference set in PLL is in nanoseconds.
Offline ale500
« Reply #16 on: February 14, 2017, 06:37:30 am »
The Max10 SDRAM example that comes with the TerAsic board DE10 Lite uses a 100 MHz clock and a phase delay of -3 ns. The NIOS example does the same.
