Nice, here is Arrows offering at $30 and with built in programmer and more goodies than the other board, but no stock yet, and their edge connector that is expensive, but I have an adaptor for it already:
http://parts.arrow.com/item/detail/arrow-development-tools/bemicromax10Edit fixed embedded image and added description:
Board Highlights
Features Altera MAX® 10 FPGA with 8,000 Logic Elements, ADC block, temperature sense diode, onchip-RAM, user flash memory and non-volatile self-configuration.
Extensible via 2 Digital PMOD Interface headers
Allows for further expansion from two 40-pin prototyping headers
One MAX® 10 FPGA (10M08DAF484C8G)
8,000 LEs
414 Kbit (Kb) M9K memory
256 Kbit (Kb) user flash memory
2 phase locked loops (PLLs)
24 18x18-bit multipliers
1 ADC block – 1 MSa/sec, 12-bit, 18-channels
17 analog inputs
1 temperature sense diode
250 general purpose input/output (GPIO)
Non-volatile self-configuration with dual-boot support
Clocking circuitry
50 MHz oscillator
24 MHz oscillator
External peripherals
8MB SDRAM (4Mb x 16) (ISSI IS42S16400)
Accelerometer, 3-Axis, SPI interface (Analog Devices ADXL362)
DAC, 12-bit, SPI interface (Analog Devices AD5681)
Temperature sensor, I2C interface (Analog Devices ADT7420)
Thermal resistor
Photo resistor
General user input / output
8 user LEDs
2 user Pushbuttons
Prototyping
Two 6-pin PMOD expansion headers
Two 40-pin prototyping headers which provide access to 64 digital I/O
6 analog inputs
One 80-pin BeMicro card edge connector
