Compiler may not know that the program is invalid. For example:
x[a] = x[b]++;
This code is invalid (and result is undefined) only if a == b.
If a = b, then the value of x[a] will remain unchanged.
The rule I know is that
the right side of an assignment is evaluated first, then the left side, then the assignment is made.
x[a] = x[a]++ is the same as n = n++. Let's say n=10.
- First we read the value (10) stored at address n, in order to further use it in the calculation of the right side expression. Other said, we make a copy of n.
- Then, we increment the content of address n. Now n will contain the value 11
- Then we continue the evaluation of the right side expression (in our case, nothing to do), so the right side result is 10. In memory, at address n is stored 11.
- Now, it's time to evaluate the left hand side of the assignment (For n=n++, there is nothing to evaluate in the left side. For x[y]=x[z]++, in the left side we will evaluate &x+y*sizeoff(x) )
- Then, the assignment: Our n, which is now 11, will receive the value calculated in the right hand side, which is 10.
So, we will end up with an unchanged value. No undefined situation. What am I missing?
Isn't the right side of an assignment always evaluated first?
