Hi All! I am having a hard time making the communication between the audio codec and the microprocessor to work. I am using the new stm32F7 discovery board
I was able to configure the audio codec to output the audio picked up by two digital mics directly to the headphone jack through the digital sidetone path. Now, I would like to send the mic data to the micro controller to do some signal processing.
However, I don't really know how the audio codec outputs the raw digital mic data through AIF1 interface so that I can properly configure the SAI2 to receive it. I know the data coming from the digital mics is in PDM format. Does the codec convert it into PCM internally before outputting?
Here is how I have configured the audio codec
Codec is set to operate as a slave.
Audio Protocol ----> I2S Standard
Sampling Rate ----> 48kHz
Data Size -----> 16 bits
Timeslot 0 is disabled and Timeslot 1 is enabled to receive the mic data.
On the microcontroller side, I have configured SAI2 as follows
SAI2_BlockA -- Master TX
SAI2_BlockB -- Slave RX ( Synchronus with BlockA)
MCLK -- ~13 Mhz
Total Slots -- 2
Frame Length -- 32
Active Frame Length -- 16
Data Size(bits) -- 16
Please let me know if more details are required. Thanks
I have read the datasheets numerous times and haven't been able to find anything on this. I also posted this on the stm32 forum, but haven't been able to get any help.
