Author Topic: anyone need this part XILINX XCVU440-2FLGA2892E  (Read 2705 times)
Offline ivan851Topic starter
« on: April 21, 2017, 08:33:42 pm »
If anyone needs this part from Xilinx
XILINX     XCVU440-2FLGA2892E.        IC FPGA VIRTEX 7 ULTRA 440K G2 LC BGA2892
Offline amitchell
Re: anyone need this part XILINX XCVU440-2FLGA2892E
« Reply #1 on: April 21, 2017, 08:37:15 pm »
Thanks, but I already have a couple just sitting on my bench.
Offline julianhigginson
« Reply #2 on: April 21, 2017, 09:44:51 pm »
awesome! that's extremely generous of you. I'll have 10 thanks!
Sent from my A0001 using Tapatalk
« Reply #3 on: April 21, 2017, 11:54:46 pm »
damn... good point. that's a lot of tinned copper wires I'll have to solder in order to use it.
I might need a tray of them just in case...
also, does anyone know where i can get a 2892 net breadboard?
Offline Kilrah
« Reply #4 on: April 23, 2017, 10:12:40 am »
Unit Price USD51.413,63
Nice, officially the highest price I've seen for a commercial IC...
« Last Edit: April 23, 2017, 01:06:01 pm by Kilrah »
Offline CM800
« Reply #5 on: April 23, 2017, 11:58:57 am »
Not sure why you'd go with that one, this one has the same number of pins and logic gates, but is also a better speed grade!
XCVU440-1FLGA2892C-ND  -> £31,468.19
XCVU440-2FLGA2892E-ND   -> £44,057.83
I wonder why?
... Ah, the expensive one is an 'Extended' Temp range, while the other one is 'only' commercial.
« Last Edit: April 23, 2017, 12:01:47 pm by CM800 »
Offline ali_asadzadeh
« Reply #6 on: April 23, 2017, 12:11:22 pm »
If you don't need them then I need them! :)
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline Kalvin
  • Embedded SW/HW.
« Reply #7 on: April 23, 2017, 01:17:10 pm »
Any reference design for double sided PCB for home etching?
The following users thanked this post: ali_asadzadeh, Kilrah
