Author Topic: anyone using Parallela ? 16-core Epiphany RISC SOC + Zynq SOC (FPGA + ARM A9)  (Read 1637 times)
Offline legacy
is anyone using the Parallella board ? ( 99 USD )
if so, for which project :D ?
the Bunker is open, at DTB!
Do not buy any shit from China!
Buy serious Chinese products!!!
Offline helius
Be aware that there is a design error on the board; the designers failed to correctly consider inrush currents (as taught in Linear Technology's AN88) and as a result they are easily damaged.
Offline blueskull
  • Country: cn
  • Power Electronics Guy
If I am to find a platform with highest GFLOPS per buck, I would use a consumer chip with OpenCL support, such as LattePanda.
The unified memory structure makes memory addressing between coprocessor and CPU not that hard to do anymore.
Offline legacy
has been fixed in the last releases ?
Offline thm_w
The psu chip used has a max Vin of 6.5V:
http://www.intersil.com/content/dam/Intersil/documents/isl9/isl9305h.pdf
http://www.intersil.com/content/dam/Intersil/documents/isl9/isl9307.pdf
AN88 posted lists an example of over 2x voltage being applied. So this chip could presumably get over 10V.
Schematic is listed as Rev 1 still. So it seems like it was not fixed?
Would be possible to add a TVS across C237: http://www.parallella.org/docs/parallella_schematic.pdf
Offline bktemp
Adding a TVS could work, but the transition of most TVS diodes is too soft for such a small voltage difference (5V->6.5V). The inrush current can easily >10A and the TVS must be able to limit the voltage at this current.
But there is a much easier solution: Just add an electrolytic capacitor of about 10x the value of the ceramic capacitor. Its ESR will dampen any overshoots.
Offline ebclr
I bought basically to play with the Zynq SOC, it's the cheapest , and util now no problem, it's used only to research on FPGA
Offline legacy
ummm, I'd like to port my SoftCore on the FPGA, too
but I'd also like to play with the Epiphany SoC  :D
