Author Topic: Arduino and decimal numbers  (Read 7806 times)
Offline miguelvp
Re: Arduino and decimal numbers
« Reply #25 on: July 09, 2015, 04:42:05 am »
In that case, then use * for width and .* for precision so you can specify them on the fly
i.e.
sprintf(txt, "%*.*f", width, precision, val);
computing width and precision should be easy enough.
I think Arduino's printf doesn't support float formatting to save space by default, but there is a way to enable that functionality.
Offline f1rmb
« Reply #26 on: July 09, 2015, 05:14:54 am »
Yeah, there is no float support, this is why dtostrf()  exists.
Also, float are double on AVR.
Cheers.
Daniel
Offline alank2
« Reply #27 on: July 09, 2015, 10:03:01 am »
I have a library for AVR gcc that is a printf that will allow you to specify the decimal places.  An integer of 123 with decimal places would be printed to a string as "1.23".
http://www.avrfreaks.net/projects/decimal-integer-sprintf-library
