Ok, I think you just want "the answer" which is a reasonable thing to want from your standpoint but no one that is here so far* seems likely to give it to you - at least not under your current approach. I don't know if the approach I suggest here will work but you might give it a try.
Edit: *while I was drafting Dave just posted a pretty direct suggestion, so there's something good to go on
When you make your next post try giving at least as much information as you are asking for. For example, you could say "I am trying to accomplish specifically X and I have done 1, 2, 3, and 4. And since 1 and 2 enabled me to do 3 and 4 I can't see why X isn't happening. I tried using both "" around each line like it says in the the Programmming Bible by Nobel Prize Winner Johnson and I also tried () around each line, and neither helped. Does anyone know if the problem is with the characters I'm using to enclose each line, or if I should be looking at some other possible cause? Thanks!" Or something like that.
The idea here is to show that 1 you have done some work, 2 you have done some research and you tried to make your work consistent with some principle you learned somewhere, 3 you have made at least one hypothesis about what has gone wrong and you tested the hypothesis, 4 you are confused by some logic that indicates your approach should work, 5 you have tried to narrow down the possible solution to this or that, 6 you are willing to do some more work if someone would kindly point you in a good direction, and 7 say thanks.
You might not need all 7 steps but if you give this a try you might get enough assistance that you will be able to solve your problem and learn something along the way.
Having said all that I realize that you are probably saying to yourself "if someone would just give me the answer (any answer that works) I could apply the answer, see it work, and then by seeing it work I will likely learn what went wrong and therefore understand and learn something new simply from observing the fix being put in place". This might be true but unless you managed to get the "here it is answer" from someone fairly early on in the thread you might be stuck because the crowd dynamic has shifted from talking tech to making a point about who has power. (People might not acknowledge that it has anything to do with power; most will insist it is all about being Socratic or intellectual or educational, etc - and it probably is in many if not most cases, but some of it is ego and some of it is occasionally just the power to make people grovel.)
The vast majority of folks here are kind and helpful but once in awhile some may come across as slightly strident or rigid. As a result, sometimes it's just a matter of how the first post in a thread comes across, how the first reply sets a tone in response to the OP, and then how the mood of the crowd starts out on a thread - and then it evolves from there. My observation is that when it comes to EE-related topics EEVblog probably has as many helpful and friendly and smart people as you will find anywhere on the Internet, so I think you are in a very good place to learn and exchange ideas about EE overall. And generally the Beginners forum is an easy place to get help but for some reason when the questions are about code the approach to Q&A stiffens a bit vs other topics. My theory on this is that coders tend to think of coding as being more about logic being developed and applied and extended, and less about the underlying facts that simply yield a result. I'm sure coders often enjoy the destination but I think they often want to ensure other (especially new) coders fully experience and appreciate the journey. I could be wrong about this theory (I'm sure we'll hear about it here shortly) but it's a guess. It might partially explain why someone earlier in this thread said something to the effect of "if you think it's tough here, wait 'til you try the coding forum".
Anyway, don't get too frustrated, don't take things too personally, stay persistent but flexible enough to adapt, and hopefully something in here will help you get the answer to your current question(s) and maybe help you with more questions and projects down the road.
