Author Topic: Argh, structure initialization with PROGMEM (AVR)...  (Read 6897 times)
Offline sleemanjTopic starter
  • Professional tightwad.
« on: October 04, 2014, 11:44:57 am »
Let's assume code like this in global scope is my intention (make sure you scroll the code, seems the forum puts a height on the code box, and it's non-obvious, which is annoying)...
byte MyImagePage000[128] PROGMEM = {
  0x0c, 0x94, 0x35, 0x00, 0x0c
byte MyImagePage001[128] PROGMEM = {
  0x02, 0xc0, 0x05, 0x90, 0x0d
#define MyImagePage002 NULL
#define MyImagePage003 NULL
byte *MyImagePages[] PROGMEM = {
    MyImagePage000,  MyImagePage001,  MyImagePage002,  MyImagePage003
 struct PagedBinData
    char          *imagename;
    unsigned int  base_address;
    byte          pagesize;
    unsigned int  pagecount;
    byte          *data[];
PagedBinData MyImage = {
  "slave",
  0x0000,
  5,
  4,
  MyImagePages
This does not compile, "too many initializers for ‘PagedBinData’"
You can see my intention is that
  1. there are pages of bytes stored in PROGMEM (MyImagePage000 ...)
  2. some of those pages are empty and are just defined to NULL
  3. a table of pointers to all the pages (some of which are therefore NULL pointers) is also stored in PROGMEM
  4. then I want to get that PROGMEM table of pointers into a standard sram structure MyImage
How do I initialize MyImage to get MyImagePages in there like I want?
« Last Edit: October 04, 2014, 11:47:22 am by sleemanj »
Offline rs20
Re: Argh, structure initialization with PROGMEM (AVR)...
« Reply #1 on: October 04, 2014, 12:53:05 pm »
Nothing to do with PROGMEM; you need to add "struct". At least, that's one issue.
struct PagedBinData MyImage = {
  "slave",
  0x0000,
  5,
  4,
  MyImagePages
OR use typedef so that you don't need to repeat struct all over the place:
typedef struct
    char          *imagename;
    byte          pagesize;
    byte          *data[];
 } PagedBinData;
« Last Edit: October 04, 2014, 12:57:58 pm by rs20 »
« Reply #2 on: October 04, 2014, 12:57:45 pm »
Nothing to do with PROGMEM; you need to add "struct". OR use typedef so that you don't need to repeat struct all over the place:
The second struct (or typedef) is not necessary in C++
It's to do with PROGMEM tangentially, because if I didn't have to use PROGMEM, I wouldn't be doing it like this :-)
« Last Edit: October 04, 2014, 01:00:25 pm by sleemanj »
Offline nuno
  • Country: pt
« Reply #3 on: October 04, 2014, 12:59:45 pm »
byte *data[];
must be initialized with a list (array) of variables of type byte*, like
  "slave",
  0x0000,
  5,
  4,
  {pointer1, pointer2, ...}
because you're declaring the array there, not a pointer to the array, which is what you want. How about
    byte          **data;
  "slave",
  0x0000,
  5,
  4,
  MyImagePages
You can still index data as an array (make sure you know where it ends).
« Last Edit: October 04, 2014, 01:02:01 pm by nuno »
« Reply #4 on: October 04, 2014, 01:05:58 pm »
    byte          **data;
Ahhh, perfect, yes that does the trick.
Funny, I was sure that I had some reason for using the other notation.  I guess it can't have been that important.
Offline bingo600
« Reply #5 on: October 04, 2014, 06:21:43 pm »
Be aware that the way you use PROGMEM will get you in trouble , when Arduino switches to a more recent avr-gcc.
Not your fault , but PROGMEM is about to be "phased out" / deprecated.
Maybe consider to use a typedef or some "#define magic" already now ... "hint" prefix with const char or maybe cinst byte for the ardu. stuff
/Bingo
Nice article by Dean C
http://www.github.com/abcminiuser/avr-tutorials/blob/master/Progmem/Output/Progmem.pdf?raw=true
« Last Edit: October 04, 2014, 06:31:53 pm by bingo600 »
Offline true
  • INTERNET
« Reply #6 on: October 04, 2014, 09:36:04 pm »
Where is this discussed / documented?
Offline SirNick
« Reply #7 on: October 05, 2014, 07:16:23 am »
Yeah, that's news to me too.  (Good PDF link though.)
Offline westfw
« Reply #8 on: October 05, 2014, 07:51:18 am »
I don't think that PROGMEM itself that became completely deprecated in the new compilers/libc.  Just the prog_xxx typedefs (prog_char, etc.   Because "attributes may not be attached to a type, only to a variable.")
However, there is now support for "named memory spaces" at the compiler level, which can make accessing data in flash EASIER than using the pgmspace.h utilities.  https://gcc.gnu.org/onlinedocs/gcc/Named-Address-Spaces.html
Also note the 24-bit "unified" __memx pointers that can be used to point to either flash or RAM.
Offline true
  • INTERNET
« Reply #9 on: October 05, 2014, 08:11:51 am »
Yes, this is what I thought was going on / what I have read, not pgmspace.h going away but rather easier flash access becoming available. Still feels like a hack (and for avr-gcc it sort of is) but it is far easier to work with than pgmspace and will likely have support for a long while.
