because i haven't seen much need of abstraction on microcontrollers yet
That's because you are looking at 8-bit MCUs. And that's exactly the problem - they are typically resource-limited, so they encourage poor design.
You say that you never had a need for 32-bit (and possibly floating point) arithmetic . I say, you have that need, but you just don't realize what a waste of time 8-bit micros are.
It is very liberating to not have to think if certain variable should be 8-bit or 16-bit, but with some performance impact, so you make it work as 8-bit. This very low-level thinking is very typical on 8-bit devices and leads to a very poor code.
Spot on. Basically i should "stop worrying and learn to love the ARM"
After all, my high school education was on Programmable Logic, PLC, pic assembly.. that sort of things.
The course i took on microcontroller programming while i was in uni was a total joke. The tutors had no idea of what they were doing almost all the time and the result was more like yet another arduino tutorial. Every time i had a problem i had to do the hard work myself, which of course is not a bad thing, quite the opposite, but you get the idea.
Been doing this professionally not for a long time time, just quite recently i started trusting the compiler for producing code that can be as clever as i would write it if not better (understandable for 8 bitters) and, most important, i accepted that i don't always have to squeeze every instruction.. i even started using divisions
but not for time critical things.
and of course, routines to talk to external chips, as a sanity check. those routines have inside them a for example "SPI_SEND" routine that will be changed if i have to port the code to another micro... i guess i'm improving a step at a time.
But again, i never worked on something high level or so complex that needed a team bigger than two persons.. and what i do is low level anyway, the user interface if present is a computer application that talks with UART
but i want/have/need to broaden my view.
