With q31, GCC needs to be be at -02 or -O3 optimization levels to get the integer DSP instructions. -O0 effectively puts the chip into "m3" mode.
The high precision biquad function with q31 is nice as it uses the SMLAL instruction (at the correct optimization levels). This means you have 64-bit precision in the state variables and accumulator.
https://github.com/ehughes/ESC-M4Goto the ESC 2017 branch.
I have quite a bit of testing on the M4/M7.
Some Highlights:
1.) Use f32 over Q31 if you have the floating point unit, it is always faster. If you want integer and speed, use q15
2.) Compile with hard ABI, especially if you are function call heavy.
3.) GCC needs to be at -02 or -03 for DSP code
4.) GCC beats Keil in about 80% of test cases of the CMSIS library when comparing speed (clock cycles).
To see the effect of the opimization level on integers:
(The rand() and Printfs are nice markers)
#include "arm_math.h"
#include "stdio.h"
#include "stdlib.h"
int main()
q63_t a=0;
q31_t b=0;
q31_t c=0;
for(int i =0 ; i< 64 ; i++)
b = rand();
c = rand();
a+=(q63_t)b*c;
//Need this so the compiler Generates what we need!
printf("%ll",a);
return 0;
-O0
1a0003e0 <main>:
1a0003e0: b5b0 push {r4, r5, r7, lr}
1a0003e2: b086 sub sp, #24
1a0003e4: af00 add r7, sp, #0
1a0003e6: f04f 0300 mov.w r3, #0
1a0003ea: f04f 0400 mov.w r4, #0
1a0003ee: e9c7 3404 strd r3, r4, [r7, #16]
1a0003f2: 2300 movs r3, #0
1a0003f4: 60bb str r3, [r7, #8]
1a0003f6: 2300 movs r3, #0
1a0003f8: 607b str r3, [r7, #4]
1a0003fa: 2300 movs r3, #0
1a0003fc: 60fb str r3, [r7, #12]
1a0003fe: e01f b.n 1a000440 <main+0x60>
1a000400: f001 fc94 bl 1a001d2c <rand>
1a000404: 60b8 str r0, [r7, #8]
1a000406: f001 fc91 bl 1a001d2c <rand>
1a00040a: 6078 str r0, [r7, #4]
1a00040c: 68bb ldr r3, [r7, #8]
1a00040e: 4619 mov r1, r3
1a000410: ea4f 72e1 mov.w r2, r1, asr #31
1a000414: 687b ldr r3, [r7, #4]
1a000416: ea4f 74e3 mov.w r4, r3, asr #31
1a00041a: fb03 f502 mul.w r5, r3, r2
1a00041e: fb01 f004 mul.w r0, r1, r4
1a000422: 4428 add r0, r5
1a000424: fba1 3403 umull r3, r4, r1, r3
1a000428: 1902 adds r2, r0, r4
1a00042a: 4614 mov r4, r2
1a00042c: e9d7 1204 ldrd r1, r2, [r7, #16]
1a000430: 185b adds r3, r3, r1
1a000432: eb44 0402 adc.w r4, r4, r2
1a000436: e9c7 3404 strd r3, r4, [r7, #16]
1a00043a: 68fb ldr r3, [r7, #12]
1a00043c: 3301 adds r3, #1
1a00043e: 60fb str r3, [r7, #12]
1a000440: 68fb ldr r3, [r7, #12]
1a000442: 2b3f cmp r3, #63 ; 0x3f
1a000444: dddc ble.n 1a000400 <main+0x20>
1a000446: e9d7 2304 ldrd r2, r3, [r7, #16]
1a00044a: 4804 ldr r0, [pc, #16] ; (1a00045c <main+0x7c>)
1a00044c: f000 fd2e bl 1a000eac <printf>
-O3
1a0003fc <main>:
1a0003fc: b5f8 push {r3, r4, r5, r6, r7, lr}
1a0003fe: 2440 movs r4, #64 ; 0x40
1a000400: 2600 movs r6, #0
1a000402: 2700 movs r7, #0
1a000404: f001 fc76 bl 1a001cf4 <rand>
1a000408: 4605 mov r5, r0
1a00040a: f001 fc73 bl 1a001cf4 <rand>
1a00040e: 3c01 subs r4, #1
1a000410: fbc0 6705 smlal r6, r7, r0, r5
1a000414: d1f6 bne.n 1a000404 <main+0x8>
1a000416: 4632 mov r2, r6
1a000418: 463b mov r3, r7
1a00041a: 4802 ldr r0, [pc, #8] ; (1a000424 <main+0x28>)
1a00041c: f000 fd2a bl 1a000e74 <printf>
