I'm trying to drive SPI peripheral of my LPC17xx MCU with the latest CMSIS libraries(CMSIS-Driver Version 2.03). I am using its example code described in the SPI Interface. The example used RTOS for driving but I want to use it in bare metal state & because of it I must find a alter for line:
osEvent evt;
that defined an evt structure in the RTX,which used to notify the events. as you know CMSIS libraries in this version has comprehensive changes & therefor earlier versions tutorial are not useful.
Example Code:
#include "Driver_SPI.h"
#include "cmsis_os.h" // ARM::CMSIS:RTOS:Keil RTX
void mySPI_Thread(void const *argument);
osThreadId tid_mySPI_Thread;
/* SPI Driver */
extern ARM_DRIVER_SPI Driver_SPI0;
void mySPI_callback(uint32_t event)
switch (event)
case ARM_SPI_EVENT_TRANSFER_COMPLETE:
/* Success: Wakeup Thread */
osSignalSet(tid_mySPI_Thread, 0x01);
break;
case ARM_SPI_EVENT_DATA_LOST:
/* Occurs in slave mode when data is requested/sent by master
but send/receive/transfer operation has not been started
and indicates that data is lost. */
__breakpoint(0); /* Error: Call debugger or replace with custom error handling */
break;
case ARM_SPI_EVENT_MODE_FAULT:
/* Occurs in master mode when Slave Select is deactivated and
indicates Master Mode Fault. */
break;
/* Test data buffers */
const uint8_t testdata_out[8] = { 0, 1, 2, 3, 4, 5, 6, 7 };
uint8_t testdata_in [8];
void mySPI_Thread(void const* arg)
ARM_DRIVER_SPI* SPIdrv = &Driver_SPI0;
osEvent evt;
#ifdef DEBUG
ARM_DRIVER_VERSION version;
ARM_SPI_CAPABILITIES drv_capabilities;
version = SPIdrv->GetVersion();
if (version.api < 0x200) /* requires at minimum API version 2.00 or higher */
{ /* error handling */
return;
drv_capabilities = SPIdrv->GetCapabilities();
if (drv_capabilities.event_mode_fault == 0)
return;
#endif
/* Initialize the SPI driver */
SPIdrv->Initialize(mySPI_callback);
/* Power up the SPI peripheral */
SPIdrv->PowerControl(ARM_POWER_FULL);
/* Configure the SPI to Master, 8-bit mode @10000 kBits/sec */
SPIdrv->Control(ARM_SPI_MODE_MASTER | ARM_SPI_CPOL1_CPHA1 | ARM_SPI_MSB_LSB | ARM_SPI_SS_MASTER_SW | ARM_SPI_DATA_BITS(8), 10000000);
/* SS line = INACTIVE = HIGH */
SPIdrv->Control(ARM_SPI_CONTROL_SS, ARM_SPI_SS_INACTIVE);
/* thread loop */
while (1)
/* SS line = ACTIVE = LOW */
SPIdrv->Control(ARM_SPI_CONTROL_SS, ARM_SPI_SS_ACTIVE);
/* Transmit some data */
SPIdrv->Send(testdata_out, sizeof(testdata_out));
/* Wait for completion */
evt = osSignalWait(0x01, 100);
if (evt.status == osEventTimeout) {
__breakpoint(0); /* Timeout error: Call debugger */
/* Receive 8 bytes of reply */
SPIdrv->Receive(testdata_in, 8);
My other question is about this type of programming? I am familiar with structures or pointers but I cannot understand why don't they use simple function in normal instead of :
As I said I can understand what above codes do ,but I can't understand why don't they use them in usual mode? for example:
int32_t ARM_SPI_Send ( const void * data, uint32_t num )
WBR.
