RaspberryPi 3 - has both Wifi and BLE-capable Bluetooth.
But otherwise concur with @krho - there isn't really much like that on the market. Most likely because Wifi & Bluetooth normally interfere with each other, so you can't just put the chips next to each other on the same board and be done with it. Some more complex logic/synchronization needs to be done. Chips able to do that are intended to work with a SoC, though, not a microcontroller.
