Author Topic: AS7 won't let me write a dot  (Read 2020 times)
Offline Simon
  • Global Moderator
    • Sparky Lab's
« on: November 02, 2015, 01:50:38 AM »
I'm trying to write: #include "timer1.h" but AS7 refuses to write the dot, with either key. In fact it won't use the dot key anywhere. So how does one write a program ?
The µCurrent has landed in Europe and now also selling Probe Master probes: http://www.simonselectronics.co.uk New stock now in.
Offline amyk
Re: AS7 won't let me write a dot
« Reply #1 on: November 02, 2015, 01:59:34 AM »
That is a weird bug...
Open the file in another text editor and do it.
Offline Simon
  • Global Moderator
    • Sparky Lab's
« Reply #2 on: November 02, 2015, 02:09:27 AM »
Extremely, the whole point of AS7 to me is the fact that I write code and it colurs text differently depending on what it is which i like.
Offline Simon
  • Global Moderator
    • Sparky Lab's
« Reply #3 on: November 02, 2015, 02:12:57 AM »
A restart seems to solve it, very weired, I seem to remember the same problem in 6.2 actually.
Online newbrain
« Reply #4 on: November 02, 2015, 02:19:14 AM »
AS7 as in Atmel Studio 7, I suppose.
Just working with it now...no problems with either key.
Possibilities:
  • HW problem: Not likely. The USB scancodes for the two keys are different
  • Key redefinition inside AS7: also not likely, VS/AS7 won't let you redefine a "visible" key.
This leave us with poltergeist...most appropriate, given the date :scared:
Additional thoughts:
  • Windows keymap problem: does the "." work outside AS7? Have you loaded a custom keymap in Windows?
  • You could try disabling all the assist function in AS7 (VAssisX)
  • Also, try to reset AS7 key to "Default"
I must say that AS7 has got a weird keyboard handling: I'm used to "Alt-arrow up/down" to move selected lines around, and there's no way I can convince AS7 to honor my setting...
Offline Simon
  • Global Moderator
    • Sparky Lab's
« Reply #5 on: November 02, 2015, 02:24:53 AM »
A restart solved it. Not impressed. Standard keyboard etc.
Offline ajb
« Reply #6 on: November 02, 2015, 04:52:24 AM »
This is a bug related to Visual Assist and is not specific to Atmel's customized version of Visual Studio.  The root cause is a corrupted .suo file (.atsuo in AS).  Closing the program and deleting the .suo/.atsuo file from your solution folder will fix the problem.  I don't know what the file is used for, but it will be regenerated the next time you open the solution.  You can also disable Visual Assist, which disables a lot of helpful features, but it's good for temporary relief.  The problem also isn't specific to the dot character, I've seen it crop up with opening parentheses and brackets as well.
Offline Simon
  • Global Moderator
    • Sparky Lab's
« Reply #7 on: November 02, 2015, 05:02:17 AM »
Ah yes that was it, parenthesis that I had the proble with before.
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
« Reply #8 on: November 03, 2015, 10:13:03 PM »
The .suo file stores the user options/settings for the solution. These are settings specific to the user not to the project(s) and is (typically) not checked into source control...
Use Ctrl-Arrows to navigate 'tokens' and press addition shift to select it...
Offline Psi
« Reply #9 on: November 03, 2015, 10:35:36 PM »
Sometimes keys just stop working in windows. Started happening in win7 and still happens randomly even in win10. Its pretty rare though, maybe once or twice a year.
I think there is a bug in the keyboard driver somewhere.
I've seen it on multiple computers. A restart always fixes it.
