By the nomenclature, sounds like you are using the Arduino IDE.
I assume you attempted to burn the (standard) bootloader, in doing so the first thing that does is set the fuses to expect a (16MHz) crystal/oscillator on it's pins, and you will need to provide that, or inject a square wave into XTAL1 in order to program again or change the fuses. Note that the bootloader won't have actually been burnt in, only the fuses will be changed at which point the bootloader could not be uploaded due to no clock.
