Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Microcontrollers
ATMega32U4 Strange Looking Clock and MOSI Signals when doing ISP
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: ATMega32U4 Strange Looking Clock and MOSI Signals when doing ISP (Read 1011 times)
bendras
Contributor
Country:
on:
June 02, 2018, 12:04:34 pm »
I am seeing strange signals when trying to program ATMega32U4 with an ISP programmer (
https://www.sparkfun.com/products/9825
to be more precise).
Anybody has any ideas on what might be causing such a stepped signal?
If I measure the clock signal which comes out of the ISP when its not connected to the ATMega32U4 board then it looks correct:
Logged
Rerouter
Super Contributor
Country:
Question Everything... Except This Statement
Re: ATMega32U4 Strange Looking Clock and MOSI Signals when doing ISP
Reply #1 on:
June 02, 2018, 12:19:20 pm »
Its defiantly not transmission line effects, At a guess its a contested pin, What else connects to that pin on your circuit?
E.g. one device is pulling or driving high, and the other is trying to drive low.
Logged
Gibson486
Frequent Contributor
Country:
Reply #2 on:
June 02, 2018, 02:22:08 pm »
Looks like you have another output or input pulling it down
One cause could be multiple push pull outputs on the same line.
Logged
bendras
Contributor
Country:
Reply #3 on:
June 02, 2018, 03:54:06 pm »
Thank you for the tips
. It turned out that the MOSI and CLOCK pins on the ATMega32U4 IC where accidentally shorted while soldering
. After removing the solder bridge everything works as expected.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Microcontrollers
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
