Author Topic: Atmel chip differences  (Read 2459 times)
Offline IvoSTopic starter
Offline ataradov
    • Personal site
Re: Atmel chip differences
« Reply #1 on: June 04, 2015, 01:01:48 am »
A versions are made using finer process, so take less silicon. Non-A versions are likely to be old stock, so they are probably were purchased by Mouser at a higher price, and they want to make their money back.
There should be no functional differences as long as your device is within specified ratings. I've seen boards where A version would fail if installed instead of non-A version, but in all of those cases absolute maximum ratings were exceeded (hi to all the people, who think that it is OK to overclock the micro).
« Last Edit: June 04, 2015, 01:10:34 am by ataradov »
Alex
Offline miguelvp
« Reply #2 on: June 04, 2015, 01:09:15 am »
Non-A seems to be older stock probably was more expensive to manufacture. Seems the A is better but I'm not going to go through the whole datasheets, but you should.
A:
• Operating Voltage:
– 1.8 – 5.5V
• Speed Grade:
– 0 – 4 MHz @ 1.8 – 5.5V
– 0 – 10 MHz @ 2.7 – 5.5V
– 0 – 20 MHz @ 4.5 – 5.5V
• Industrial Temperature Range: -40°C to +85°C
• Low Power Consumption
– Active Mode:
• 210 µA at 1.8V and 1 MHz
– Idle Mode:
• 33 µA at 1.8V and 1 MHz
– Power-down Mode:
• 0.1 µA at 1.8V and 25°C
non-A:
– 1.8 – 5.5V for ATtiny24V/44V/84V
– 2.7 – 5.5V for ATtiny24/44/84
• Speed Grade
– ATtiny24V/44V/84V
• 0 – 4 MHz @ 1.8 – 5.5V
• 0 – 10 MHz @ 2.7 – 5.5V
– ATtiny24/44/84
• 0 – 20 MHz @ 4.5 – 5.5V
– Active Mode (1 MHz System Clock): 300 µA @ 1.8V
– Power-Down Mode: 0.1 µA @ 1.8V
Offline Bruce Abbott
    • Bruce Abbott's R/C Models and Electronics
« Reply #3 on: June 04, 2015, 01:12:35 am »
The A version draws less current and has an enhanced power-on reset circuit. See app note AVR526.
Offline matseng
    • My Github
« Reply #4 on: June 04, 2015, 02:31:08 am »
Both have a "Factory lead time" of two weeks - which might mean that Atmel either have their own "old stock" on hand or are still manufacturing the Non-A part.
Offline JoeN
  • We Buy Trannies By The Truckload
« Reply #5 on: June 04, 2015, 02:38:05 am »
Have You Been Triggered Today?
