Hello All,
I designed a rudimentary back plane that has ~50 parallel pins. Currently, 8 pins are for the address line, 8 pins are for the data lines, 1 pin is for a clock, and 1 pin is for a not Read/Write command.
These pins go into an FPGA where each register compares the address with its own address as a select, and then depending upon not read/write command, inputs or outputs the data. I have tested reading/writing a few registers and it works fine. I am now looking to have read registers where the user can read data from a FIFO. Is there a standard approach to attaching a FIFO as a read register on an interface such as this?
Thanks for you help.
