I am all new here, and actually came here because I cant seem to figure out this problem, some extra knowledge might come in handy!
I am using a BNO055 NDOF chip to measure the angle of a small "Segway" kind of thing, so just a reversed pendulum system,
but the euler angles have a MASSIVE amount of drift on them.
The measured angle of the robot just lying down ( so always the same ) can vary with as much as 5 degrees....
But, the system doesn't seem to fully calibrate, I can calibrate the magnetometer, the gyro and the accelero,
but the "system" calibration ( which is a calculation according to the datasheet ) stays 0, so not calibrated.
Has anyone here more knowledge about these sensors and why I can't seem to calibrate it?
Thanks in advance!
Sam
VUBrussels, MSc. Engineering Technologies - Electronics & ICT
